help with my buildPost Date: 2009-01-01 |
| Author | |
Jmc1
Joined: 01 Jan 2009 Online Status: Offline Posts: 5 |
Topic: help with my buildPosted: 01 Jan 2009 at 11:01pm |
Need help with my build. System will be used for gaming and multi tasking, e.g., database, spreadsheet, web browsing, etc. Like to spend $5,000 or less, but don't want to compromise performance and upgrade capability. Selected lc for CPU only-is that a problem? Will this cause video card overheating problems? I have also read some posts that suggest Corsair Dominator/i7 issues. Should I select other RAM?
Specifications: Chassis Model: Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Interior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 Extreme Edition 965 3.2GHz (Quad Core) (Extreme Performance) Motherboard: ASUS Rampage II Extreme (Intel X58 Chipset) (Supports Triple SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Corsair Dominator DHX (High-Performance) Power Supply: 1000W PC Power & Cooling (Turbo-Cool Edition) (Dual/Triple/Quad SLI Compatible) Card Reader: - No Thanks Hard Drive Set 1: Operating System: 300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Hard Drive Set 3: Backup\Misc.: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Optical Drive 1: DVD-ROM/CD-ROM (DVD Reader 16x / CD Reader 40x) Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 280 1GB) (Includes PhysX Technology) Add-on Card: Pinnacle PCTV HD Card (HDTV, Video Recording, Video Capture, FM Audio) Sound Card: CLEARANCE HOT SELLER: Razer Barracuda AC-1 (Recommended) Extreme Cooling: H20: Stage 3: High-Performance Liquid Chilled FrostBite System For CPU Liquid Color:- Not Applicable, I do not have a H20: Stage 3 Cooling System Selected Chassis Airflow: Upgrade Chassis With Zalman Performance Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - No Thanks Chassis Mods: - No Thanks Boost Processor: Yes, Overclock the processor as much as possible with complete stability Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Tweak Windows: - No Thanks, Please do not tweak the services on the operating system Windows OS: Dual Boot (Windows XP Home & Windows Vista Home Premium (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks LCD Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty |
Posted: 02 Jan 2009 at 12:06am |
please post your ticket number
Jmc1
Posted: 02 Jan 2009 at 8:09am |
Here it goes, thanks Ticket Number: 222671 |
graavin
Joined: 22 Nov 2008 Online Status: Offline Posts: 100 |
Posted: 02 Jan 2009 at 9:26am |
Don't forget to choose your Liquid Color! And depending on what you get, you may want to adjust your Internal Lighting.
Also, the Zalman Performance Fans will increase air-flow, but they're also kind of loud. I think Air-cooling your 2 cards should not be a problem. I have 2x GTX260s, and at 40% fan speed, they usually idle at 40-42 degrees celcius, at 100% they get down to 35-37 degrees. I'm using LED Performance fans, just to give you an idea. And with all the fines combined, it doesn't seem to be intolerably loud unless I turn the GPU fans over 80%. As to your other questions, I don't have any answers to those. Hopefully DST4ME will get back to you soon! Edited by graavin - 03 Jan 2009 at 7:35am |
Posted: 02 Jan 2009 at 11:15pm |
here you go Ticket# 223731 --- Price: $5309 (To see this build click here)
Copy of Specifications: Chassis Model: Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Interior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 Extreme Edition 965 3.2GHz (Quad Core) (Extreme Performance) Motherboard: ASUS Rampage II Extreme (Intel X58 Chipset) (Supports Triple SLI or CrossFire) System Memory: 6GB DDR3 1866MHz OCZ Platinum Edition (Extreme-Performance) Power Supply: 1000W PC Power & Cooling (Turbo-Cool Edition) (Dual/Triple/Quad SLI Compatible) Card Reader: - No Thanks Hard Drive Set 1: Operating System: 300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Hard Drive Set 3: Backup\Misc.: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition) Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 280 1GB) (Includes PhysX Technology) Add-on Card: Pinnacle PCTV HD Card (HDTV, Video Recording, Video Capture, FM Audio) Sound Card: CLEARANCE HOT SELLER: Razer Barracuda AC-1 (Recommended) Extreme Cooling: H20: Stage 3: High-Performance Liquid Chilled FrostBite System For CPU Liquid Color:UV Green: High Glowing Non-conductive Fluid (Requires H20: Stage 3 & UV Lighting) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect For H20: Stage 3 UV Fluid) Enhancements: - No Thanks Chassis Mods: - No Thanks Boost Processor: Yes, Overclock the processor as much as possible with complete stability Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Tweak Windows: - No Thanks, Please do not tweak the services on the operating system Windows OS: Dual Boot (Windows XP Home & Windows Vista Home Premium (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks LCD Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty I just upgraded a couple of things. Your ram was fine but I upped you to the 1866MHz. Do you know that the rampage comes with a sound card? Edited by DST4ME - 02 Jan 2009 at 11:20pm |
