Help with my computer? :D
Post Date: 2014-10-10
fizziepanda View Drop Down
  Quote fizziepanda Quote  Post ReplyReply bullet Topic: Help with my computer? :D
    Posted: 10 Oct 2014 at 5:39pm
Hey everyone! I'm setting up a new design, and I'm new to Digital Storm.
I'm hoping to get some feedback on my design:
Is this a good setup? (For high quality gaming)
Will the setup work?
Is the power supply good enough?
Is there anything that I maybe shouldn't get?
Configuration Code: 1061699
Processor: Intel Core i5 4690K 3.50 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core)
Motherboard: ASUS Z97-PRO (Intel Z97 Chipset) (Features 802.11ac Wi-Fi Connectivity)
Storage Set 1: 1x Storage (1TB Western Digital - Enterprise Edition)
Storage Set 2: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX TITAN Black 6GB (Includes PhysX)
Airflow Control: - No Thanks
Chassis Mods: Fan Blow-Hole: Graphics Card Area Only: Laser Cut and Mount a Side Window 140mm Fan
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
Edited by fizziepanda - 10 Oct 2014 at 6:11pm
Ariktu View Drop Down
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 10 Oct 2014 at 6:17pm
If you are doing gaming I would go with these changes.
Configuration: 1061720
Storage Set 1: 1x SSD (250GB Samsung 840 EVO)
I added the overclock since you had the stage 2 cooling so might as well get the stage 1 overclock for extra performance. I left in the blow hole since why not.
Moved to a GTX 980 since the titan is likely not needed. The GTX 980 offers better gaming performance anyway.
The PSU is fine.
Edited by Ariktu - 10 Oct 2014 at 6:22pm
  Quote fizziepanda Quote  Post ReplyReply bullet Posted: 10 Oct 2014 at 8:05pm
Hmm interesting! @Ariktu
Is the 980 better than the Titan? I always thought the more video memory you had the better the game would run.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 10 Oct 2014 at 9:10pm
here is the comparison between the two
http://www.anandtech.com/bench/product/1186?vs=1351
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 11 Oct 2014 at 3:07am
I agree with Ariktu and the link Arkansas posted shows why.   The gtx 980 is at least as good and usually better for gaming than the Titan Black. The added vram, 6gb vs 4gb, isn't needed even for 4K monitors. If you were into scientific modeling, math intense applications then the TItan is worth it.   980 is a lot less wattage and saves $500.
Good luck.
