Help with my configuration
Post Date: 2008-08-22
cbenioff View Drop Down
  Quote cbenioff Quote  Post ReplyReply bullet Topic: Help with my configuration
    Posted: 22 Aug 2008 at 2:57pm
My current machine is failing so I am looking into a new gaming rig despite the fact that I am not currently playing anything.  Normally I play MMOs and not much else (LOTRO, AoC, etc..).
My idea with this configuration is to keep it cheap but allow for upgrading the RAM and video card when I need the performance boost.  I will be using my current video card for now (8800 GTS 512mb OC).  I am open to possibly going SLI at some point, but its more likely I will stick with single card upgrades.  I think I will eventually get 8gb of RAM... seems to be cheaper to get the RAM off newegg than buy it preinstalled.
I am skimping on the motherboard... is this going to be ok?  From what I found, all the boards are pretty similar.
Do I really need a 750W ps?  Future video cards are my consideration.
Will stage 1 cooling be sufficient?  MY video card doesn't run too hot.
I've got an external HD so no need to get 2.
Is the extra $226 for the Q9550 2.83ghz processor worth it?
Here is the configuration:
Chassis: Antec 900
Power Supply: 750W Corsair HX (Dual SLI Compatible) (Silent Edition)
Processor: Intel Core 2 Quad Q9450 2.66GHz (1333MHz FSB) (12MB Cache)
Motherboard: CLEARANCE PRICED: NVIDIA 680i LT SLI Core 2 Quad (Chipset: nForce 680i SLI)
System Memory: 2GB DDR2 Corsair at 800MHz XMS2
Card Reader: - No Thanks
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: - No Thanks, I will be installing my own video card(s)
TV Tuner: - No Thanks
Sound Card: Creative Sound Blaster X-Fi XtremeGamer
Extreme Cooling: Air Cooled Stage 1 (Certified Digital Storm Heat-sink)
Modifications: - No Thanks
Protection: - No Thanks
LCD Display: - No Thanks
Thanks for your help!
Lawdog View Drop Down
  Quote Lawdog Quote  Post ReplyReply bullet Posted: 22 Aug 2008 at 5:44pm
The 750w power supply will be necessary if you have any plan of the possible SLI/Crossfire in the future.
As far as the extra $226 for the processor I would have to say it's not really worth it.
I would however suggest going with the stage 3 cooling as it looks as though you are having them do some overclocking.  You'll get a much better OC with the extra cooling and your system with be better able to handle the stress of an OC.
If you are really looking to save a few bucks going with onboard sound is another option as it's fairly easy to add a sound card later.
Sneakerz View Drop Down
  Quote Sneakerz Quote  Post ReplyReply bullet Posted: 22 Aug 2008 at 6:21pm
I have to agree with Lawdog on the Stage 3 cooling especially if you are doing an OC. Stage 1 cooling will not be enough.
Intel Core i5 6600k @ 4.6
240GB Samsung SSD
Nvidia GeForce GTX 1070 Hybrid
Corsair Hydro H80i GT
  Quote cbenioff Quote  Post ReplyReply bullet Posted: 22 Aug 2008 at 6:49pm
Thanks for the feedback.  How much better is Stage 3 cooling over stage 2 or stage 1?  Consider also I am going with the smaller case... I don't know how much that plays a role in the effectiveness of cooling.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Aug 2008 at 7:29pm
If you want to OC then go with liquid cooling, you will get lot higher speeds from it. If not liquid then atleast stage 3, otherwise drop the OC from your config.
Go with 4GB of ram.
Go with 4 year warranty
You got no graphic card but you getting a sound card? why not drop the sound card and call DS and ask them to install the graphic card you want? Its gonna be tough testing your PC without a graphic card.
