Help with my digital 7.1 output Marauder Lvl 3
Post Date: 2012-08-30
Doxiedad View Drop Down
  Quote Doxiedad Quote  Post ReplyReply bullet Topic: Help with my digital 7.1 output Marauder Lvl 3
    Posted: 30 Aug 2012 at 11:07am
Ok so I've loved my Marauder lvl 3. I've been using stereo headphone with it and it's awesome.
Recently I decided to hook my Turtle Beach X41 5.1 headphones up to it. I ran the digital optical cable from the back of the PC to the base of the X41.
I can get sound, but I have to press the bypass button to get it to play.
I'm not sure if that is because my computer is sending it stereo or because it's sending 5.1/7.1
Any help would be greatly appreciated
  Quote Alex Quote  Post ReplyReply bullet Posted: 30 Aug 2012 at 1:18pm
I'm not sure what may be the issue. Perhaps Turtle Beach would know how to fix that?
  Quote Doxiedad Quote  Post ReplyReply bullet Posted: 30 Aug 2012 at 1:20pm
Ok, Yeah I've got an email out to them.
So if I have it hooked up to the digital optical output for audio it's going to send whatever the game sends out right?
I couldn't find any settings for forcing it into stereo or 5.1
Thanks.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 30 Aug 2012 at 3:21pm
Hi Doxiedad,
Are these X41 headphones that you used with an Xbox and now you want to use them on your PC? Do they have a mike to hook up? Is this a wireless headset?
If this is the wireless headset I think it is, how are you powering the transmitter module. The Toslink cable doesn't provide power to the transmitter. You should be able to plug a HDMI cable into the transmitter and into the transmitter module for power.
I may be all wet and should have waited until you replied to my questions.
Edited by FrankW - 30 Aug 2012 at 3:39pm
  Quote Doxiedad Quote  Post ReplyReply bullet Posted: 31 Aug 2012 at 5:54am
Originally posted by FrankW
Hi Doxiedad,
Frank, yeah this is the wireless system for the Xbox 360. I have the toslink going from my pc to the base station, the base station draws power from a USB port.
I think I finally got it figured out, I had to go in game and tell it I was using the digital optical output for audio.
Now sadly after getting that figured out I discovered that there is a lot of cracking and popping in the headset.
I did some research and Turtle Beach used 2.4ghz to connect base and the headphones, unfortunately this is the same as my WirelessG router
I've all ready tried changing channels on the router but no luck. The way my system is setup I can't get more than 6 feet between the router and the base if I want to use it on my pc. Playing Xbox in the living room is not a problem because there is about 30 feet or more separation.
Looks like I'll have to keep using my Gamecon stereo headset for a while since its wired.
Oh and if I wanted to use the mic with the pc there is a $10 adapter that lets it plug into the audio in jack.
TL;DR
Fixed the problem but interference won't let me use it.
Thanks for the help like always.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 31 Aug 2012 at 7:16am
Hi Doxiedad,
Glad to hear you got it sorted out.
You might want to try shielding the router or the Turtle Beach transmitter with aluminum foil that is grounded. If you have the computer hard wired to the router then I would try to block the signal from the router. Copper screen makes a great shielding material. If you are using the computer with a wireless connection it may not work. You can try shielding the headset transmitter module so it only radiates towards you and not towards the router.
