help with my set-up
Post Date: 2009-10-25
applesaging View Drop Down
  Quote applesaging Quote  Post ReplyReply bullet Topic: help with my set-up
    Posted: 25 Oct 2009 at 7:09pm
Trim Accents: Paint Screws and Hose Clamps (Red)
Processor: Intel Core 2 Extreme QX9650 3.0GHz (Quad Core) Factory Overclocked to 3.60GHz
Motherboard: Intel Desktop Board DX48BT2 (Chipset: Intel X48)
System Memory: 4GB DDR3 1333MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Card Reader: - No Thanks
Video Card: !CLEARANCE HOT SELLER: 1x NVIDIA GeForce GTX 275 1792MB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 1: CLEARANCE HOT SELLER OCZ Vanquisher 775 CPU Fan  (Not Compatible With i7 Processors)
Windows
OS: Microsoft Windows 7 Home Premium (64-Bit Edition)
LCD Display: - No Thanks
what do you guys think about my set up? do i need to change or remove some stuff? :l (to make it cheaper :P)
thx guys.
:D :l :) :D :( D:
MyNameisBrian View Drop Down
  Quote MyNameisBrian Quote  Post ReplyReply bullet Posted: 25 Oct 2009 at 7:34pm
What are you using this computer for, what is your budget, and what resolution is your monitor?
  Quote applesaging Quote  Post ReplyReply bullet Posted: 25 Oct 2009 at 9:05pm
for running crysis, L4D, CS etc..
that's another problem :l i don't know what monitor to buy :P can u suggest a good but cheap one?
my budget is around $1500-$2000
:D :l :) :D :( D:
  Quote MyNameisBrian Quote  Post ReplyReply bullet Posted: 25 Oct 2009 at 10:26pm
Try this ($1885)
Interior Finish: - Not Available
Trim Accents: - Not Available
Card Reader: - Not Available
Extreme Cooling: AIR: Stage 2: Noctua NH-U12P High Performance Cooler (Compatible With ONLY i5/i7 Processors)
Liquid Color:- Not Available
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Tweak Windows: - Not Available
Office: - Not Available
Benchmarking: - Not Available
  Quote applesaging Quote  Post ReplyReply bullet Posted: 25 Oct 2009 at 11:15pm
thanks this really helped :)
:D :l :) :D :( D:
  Quote applesaging Quote  Post ReplyReply bullet Posted: 25 Oct 2009 at 11:18pm
1 question, does it really need to be 1000W?
:D :l :) :D :( D:
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Oct 2009 at 12:01am
before we can tell you what gpu to get we need to know what the resolution you intent to run is.
so first we need to figure out what size monitor you plaining on getting.
  Quote applesaging Quote  Post ReplyReply bullet Posted: 26 Oct 2009 at 12:18am
:D :l :) :D :( D:
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Oct 2009 at 11:48am
well the system MyNameisBrian has posted is good but the resolution of your monitor is 1900 x 1200, which means if you want to play at highest settings you will need either 1 x 5870 or 2 x 5850 or 2 x 275, keep in mind that the 275 gtx does not support dx11.
1000w psu is best so that you have room to grow but a 750w will due also.
This page was generated in 8.789063E-02 seconds.
