Help with new system
Post Date: 2009-09-21
T Hammer View Drop Down
  Quote T Hammer Quote  Post ReplyReply bullet Topic: Help with new system
    Posted: 21 Sep 2009 at 6:20pm
Hi. I was hoping to get some help with system selection for my budget. I just returned my Dell XPS 630i and am done dealing with them for anything. After looking around I plan on purchasing a DS as soon as I receive my refund from Dell.
I currently have around $2500 to spend for everything. CPU, monitor, speakers and would like help with what setup I should use.
I pretty much play video games in my spare time, and play all types. I would want a system that I am able to run with all graphics turned on and perferably up all the way.
My last system I was good, but not able to max out graphics. I used to run my graphics at 1680x1050x32. Any help would be appreciated. Thanks in advance!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 6:40pm
Well the prices are going to be a bit higher here cause they use higher end parts then Dell does.
now first we need to know what resolution the monitor you want to get has so we can match the gpus to it.
so can you tell us what size monitor you are looking for?
  Quote T Hammer Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 6:43pm
I understand that you are higher then Dell.. But at this point I am willing to maybe put some extra in if required to make a nice system. I don't really have a monitor selected yet. I was hoping to at least stay with what I had 22" unless there is a good deal for something bigger.
I online simulate race quite often and would want an option to maybe go to three monitor setup at somepoint down the road also.. I forgot to mention that and thought it would be important in the selection process.
Edited by T Hammer - 21 Sep 2009 at 6:46pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 6:50pm
LOL well listen I'm just a customer like you, so don't think I work for DS, I don't.
ok so you got a 22" and I'm assuming it has a 1600 x 1200 res then like you stated above, I thought you were looking for a new monitor.
ok then, here is the deal, right now the preconfig systems are prices very low, all you need is a single 275 to run your games at highest settings at 1600 x 1200, but if I config a custom system for you, it will endup being higher then a prebuild with 2 x 275.
so my sugggestion to is to go with extreme 2 pre build, but if you want a sound card and such then we need to build you a custom config as that prebuild will not have room for any other card then the 2 x 275.
your thoughts? btw the custom config would be around $2100 with 1 x 275 where as the prebuild is $1,946 with 2 x 275.
the difference would be that the custom build will have much more room to grow with you.
Psimon View Drop Down
  Quote Psimon Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 6:53pm
Just too much fun configuring a new system. Here's my 2 cents for DST4ME to pounce on  Embarrassed
Just to take a stab at it, with $2500 I'd go for:
Haf 922 Case
Intel Core i7 920 2.66Ghz (quad-core)
XFX X58 3X SLI mobo
1000w Corsair HX
1x500GB Western Digital (16 MB Cache) (7200 RPM)(SATA)
DVD Writer 20x (the standard one they offer)
2x SLI Dual Nvidia GeForce GTX 275 896MB
Noctua NH-U12P High Performance Cooler
CPU overclocked to 3.3 to 3.9 Ghz
Overclock the Video Boards
MS Windows Vista Ultimate Edition w/Windows 7 Upgrade Coupon
3 Year Warranty
. . that comes out to about 2636.00, -200 discount = 2436.00
There's room to play around with things. The 1000HX Corsair is a bit overpowered for the vid boards, you could probably get away with a 750 watt. I like to err on the side of caution as far as PSU's go, and if you ever go 3X SLI, the power's there when you need it.
Could also add a lil' bling like interior lighting if you wanted.
The 922 is a mid-tower, since you originally bought a smaller Dell I didn't configure the larger HAF 932. Frankly the price diffferences aren't that great, you could go any chassis. Me, I like nice, big, roomy towers, and the HAF 932 looks killer.
I also prefer the dual Velociraptor's, but they're pricey, especially the 300MB. You really can't fly with only 150gb on a Windows Vista system, not unless you got some auxilary HDD's to put in there. You could go RAID0 with two WD 7200RPMs at least, get a lil' performance increase.
Lastly, never a bad idea to buy more warranty if you can.
DST4ME will help you out I bet.
Edited by Psimon - 21 Sep 2009 at 6:54pm
  Quote T Hammer Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 7:01pm
Actually I do need a monitor also..
  Quote Psimon Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 7:04pm
Whups.
Well, I'd look at the Extreme 2 then - I'd do research on the eVGA X58M motherboard - and if that's a good one, then I'd have $500 or so left to get that nice monitor.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 7:13pm
@T Hammer, so do you want to go with a prebuild or you need room to grow and you to see a custom config?
evga x58M is a micro board with only 2 pci slots as I mentioned, this is why it will hurt growing down the road, it has no more room to grow, other then that its a good board, evga is a great company.
you can check it out here
@Psimon, xfx board has bad references from DS techs so I stoped recommending it. the LE would be a better option.
ocing the gpus is pointless.
vista ultimate is not needed, premium will do great.
other then that good build oh 932 would be better for temps.
Edited by DST4ME - 21 Sep 2009 at 7:15pm
  Quote Psimon Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 7:25pm
That's true with any about any (decent) Tower, yeah. Another reason I prefer them!
Why is OCing the GPU's pointless?
Dangit, now you got me worried about the mobo . . . . . you fiend.Shocked
  Quote T Hammer Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 7:28pm
Honestly the prebuild one is looking pretty good.. Out of 4 or 5 pc's I have only added ram once so upgrading is probably not all that important if you start with something good.
Will I have problems in the future if I would want to upgrade to say 3 monitors..
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Sep 2009 at 7:46pm
monitor-wise you would not have any problems.
@Psimon, ocing the gpus will not make a difference for you to notice the difference, however the heat they put out is very noticeable and not needed.
  Quote T Hammer Quote  Post ReplyReply bullet Posted: 25 Sep 2009 at 6:13pm
Just purchased the Extreme 2. Thanks guys!!  Heart
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 25 Sep 2009 at 10:19pm
T Hammer,
You got a beast that will be headed your way soon.   This is the time to start doing back-ups on the old system and getting the new home ready for your dream machine.
Your configuration will run like nothing you may have seen before.  The gaming experience with a Digital Storm beast is incredible.  Like yourself I was a Dell customer and wanted to kick it up a notch and then I found this forum.  I have been extremely statisfied with my new system.
The forum here will be a place that you will want to visit often and it helped me pick out my system and learn to best optimize my gaming experience.
Welcome to the Digital Storm community!!!
Ermm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Sep 2009 at 11:28pm
Congrats don't forget pics and specs when you get it
aias49 View Drop Down
  Quote aias49 Quote  Post ReplyReply bullet Posted: 26 Sep 2009 at 1:36pm
Congrats, Enjoy!Ermm
Ticket #266218
HAF 932 Case
Core I7 920 @ 3.4 GHz
GTX 295, 500 GB HDD
6 GB Mushkin Ram
  Quote T Hammer Quote  Post ReplyReply bullet Posted: 30 Sep 2009 at 4:29pm
Stage 2 -Stage 5 in one day. Been stuck on stage 5 since Monday. What gives I am dying to get my new PC!!!!
