Help with pc probe
Post Date: 2008-03-19
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Topic: Help with pc probe
    Posted: 19 Mar 2008 at 2:01am
Hey all! I'm getting some whacked readings for voltages and cpu temp for my new pc. The Asus pc probe II says my cpu temp is 157 degrees celsius and has been like this since I turned it on. I've been playing games and surfing the internet with no problems and it's not running hot. Why am I getting such weird readings?
Everest shows the same mobo temp at 56 degrees celsius, but cpu temp is 45 degrees celsius. Still, the low voltages readings match on both pc probe II and Everest. My yahoo is widdlecat01 if you can talk me thru this please! Thank you much!
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 19 Mar 2008 at 3:39am
K den! I solved the problem with my Asus pc probe II readings. Apparently when I have it running and Everest at the same time, they have a conflict and scramble the sensor. I reboot and only bring up one or the other and I'm fine. pc probe says I'm all green! yay! cpu actually is sitting at 35 degrees celsius atm. I just wish I could quiet down the cooling fan.
This page was generated in 4.785156E-02 seconds.
