Help with PC
Post Date: 2020-05-09
bambi View Drop Down
  Quote bambi Quote  Post ReplyReply bullet Topic: Help with PC
    Posted: 09 May 2020 at 6:19am
I have always played console and I was hoping to get a upgrade by getting a pc so I chose the Lumos. I wanted to go over what I have and see if I need to upgrade anything.
model. digital storm lumos
exterior finish. standard
trim finish. standard
processor. intel core i7-9700k(4.9Ghz turbo)(8cores)3.6Ghz
motherboard. msi mpg z399 gaming plus (intel x390 chipset (upto 2x pei-r device’s)
memory. 16gb ddr4 3200mhz digital storm performance
power supply. 850w corsair/evya/thermaltake
exspantion bay. no
optical drive. no
storage set 1. 1x ssd (500 gb digital storm)
storage set 2. 1x storage (2tb seagate/toshiba/hitachi)
storage set 3. no
no raid card or options
internet high speed network port
graphics card. 1x geforce rtx 2070 super 8gb (vr ready)
soundcard. integrated motherboard audio
hpc processor no
extreme cooling. h20 stage 1 digital storm votex liquid cpu cooler (single fan)
no hydrolux
premium cable management
no airflow control
standard chasis fans
no chasis mods no noise reduction
no laser mark
stock cpu boost
no graphics card boost
and stock software
I am going to get a msi wqhd 2k 144 hz 1ms 2560 x 1440 27” monitor but I can change if there are any recommendations
please if there is anything I should change to get a better result please say.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 09 May 2020 at 7:02am
The DS SSD is a SATA M.2. For $21 the Seagate NVMe SSD is 5 times faster. No-Brainer. You will thank yourself every day.
I would get the dual fan all-in-one CPU cooler. Not a place to save IMO.
The MSI board is okay, but the Rog Strix is stronger without costing much more.
The Stage One overclock is free and safe with the dual fan AOI. Don't need it, could get it if you want.
You will love the RTX 2070 SUPER!
  Quote bambi Quote  Post ReplyReply bullet Posted: 09 May 2020 at 7:56am
Thank you for rhe advice i just have one question what do you mean “The DS SSD is a SATA M.2” im new to the terms of parts
  Quote bambi Quote  Post ReplyReply bullet Posted: 09 May 2020 at 8:01am
when you say”seagate nvme ssd” are you talking about the 1x ssd m.2 (500 gb seagate firecuda 520) (nvm exspress) (gen4 pcie)
  Quote bambi Quote  Post ReplyReply bullet Posted: 09 May 2020 at 8:12am
One last question should i get a 1920 x 1080 monitor or a 2560 x 1440 144hz
im just wondering what i should get to give me the best experience
  Quote Cretae Quote  Post ReplyReply bullet Posted: 09 May 2020 at 8:46am
-SATA= Serial ATA, the old tech that has become incrementally faster since 2001. Not obsolete, but NVMexpress uses the same interface as video cards and some other peripherals in the slots on the motherboard. It is much faster, and can reach up to 5x as fast. Ideal for the OS and apps you use all the time. Everything opens instantly and you boot to desktop in well under a minute. Maintenance software that scans your drive for malware or viruses executes in seconds instead of minutes. Should be room for several of your favorite games.
-Yes, 500GB Seagate Firecuda 520.
- The RTX 2070 is very good enough for 2560x1440 (1440p) at frame rates well above 60fps on high settings. It's a bit overpowered for 1080p.
This page was generated in 2.050781E-02 seconds.
