help with ram upgrade
Post Date: 2010-02-12
biLLythek1d View Drop Down
  Quote biLLythek1d Quote  Post ReplyReply bullet Topic: help with ram upgrade
    Posted: 12 Feb 2010 at 9:09pm
i currently have 3gb (3x1gb) of ram and am looking to upgrade to 6gb.  I cannot find another set of my current memory modules sold anywhere.  what are my options to upgrade? thanks.
current memory: corsair dominator xms3-1333 9-9-9-24 (cm3x1g1333c9d6)
board: evga x58 sli
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Feb 2010 at 10:16pm
is this not gonna be back in stock?
otherwise best thing to do is just find a 1333MHz ram with the same timing.
Edited by DST4ME - 12 Feb 2010 at 10:19pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 12:11pm
my suggestion, remove your old RAM, sell it, keep it for backup, ect. Replace it with 3x2Gb sticks, of decent RAM 1600Mhz with CAS 7 or lower timings.. Your PC will be much happier.
  Quote biLLythek1d Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 12:47pm
i'm trying to prevent buying all new ram, but can't find any ram for sale with the same timing.  anyone know where i could find it for sale?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 1:17pm
understand, just giving my $.02 for a very small amount of $$ you can get 2 times the memory performance, and not put a crap load of extra load on the integrated memory controller, and when 6Gb is not enough you could add another 6Gb.
If you are bound dertermined to use that RAM, just throw another set of RAM in with the same specs, it is hard to find that crappy of RAM, but here is some that will work.
  Quote biLLythek1d Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 9:11pm
sorry, one more question from a n00b.  is it correct that the timing of the memory is set by the manufacturer and the speed can be set in the bios? thanks.
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 9:48pm
You should be able to set timings in the BIOS, I've done it over the phone with Digital Storm when I had to redo my overclocks.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 10:17pm
timings and RAM speed are set in the BIOS.
the RAM manufacturer states what the RAM is capable of performing (speed/timings) at given voltage
  Quote biLLythek1d Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 12:51pm
If I can change the timings and the speed then do I need to buy new ram that has the same speed/timing as my old ram?  thanks
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 12:54pm
 it can have better specs, just not lower specs, but matching it up is best
  Quote biLLythek1d Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 12:58pm
Do you think i will really see noticeable difference if I upgrade to completely new ram?  For example 6gb at 1600Mhz at 8-8-8-24, instead of buying 3gb more of 1333Mhz at 9-9-9-24.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:12pm
what is your CPU overclock?
  Quote biLLythek1d Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:13pm
I believe 3.4Ghz.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:18pm
if it is 3.4Ghz then you won't have to adjust the Overclock speed, just the RAM multi, Uncore multi, if it is higher than that, then a slight Overclock adjustment will be needed.
If your temps are good now, you can also raise the overclock some while you are at it, I can help out if you want to.
So, going from 1333 CAS 9 to 1600 CAS 8 is a decent Bandwidth jump, won't make a huge difference, like going from 3 to 6 Gb, but it will help, and will make upgrading to 12Gb a lot easier some day, if you need to.
  Quote biLLythek1d Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:37pm
OK, so here are my options.
1) buy additional 3gb 1333mhz, 9-9-9-24 for ~$85
2) buy additional 6gb 1333mhz, 9-9-9-24 for ~$165 (total 9gb in my system)
3) buy new 6bg 1600mhz, 8-8-8-24 for ~$200
4) buy new 6gb 1600mhz, 7-7-7-20 for ~$250
or something else entirely
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:41pm
  Quote biLLythek1d Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 2:19pm
sounds good.  i'll go for it. thanks for the advice.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 2:53pm
Thats a good set with good timings
