Help with set up
Post Date: 2022-01-24
colemanrussel View Drop Down
  Quote colemanrussel Quote  Post ReplyReply bullet Topic: Help with set up
    Posted: 24 Jan 2022 at 4:20am
So I have my own graphic card. How would this work if I dont want to buy theirs and my set up has cooling gpu+cpu? Or like do i ship you guys my gpu? Or do I do it myself when it ships to my house? How does it work?
Spec build
Exterior Finish: Exotic Paint Finish - Blanco White
Motherboard: ASUS ROG Maximus XI Hero (Wi-Fi) (Intel Z390 Chipset) (Up to 3x PCI-E Devices)
System Memory: 32GB DDR4 3200MHz Corsair Dominator Platinum DHX (Extreme-Performance)
Power Supply: 1000W Corsair HX1000 (Fully Modular)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (512GB Samsung 970 PRO) (NVM Express) (Extreme Performance)
Storage Set 2: 1x SSD (1TB Samsung 860 EVO)
Graphics Card(s): (No thank you)
HydroLux Fluid Color: Blue Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System)
Airflow Control: - No Thanks
Branded Gear: - No Thanks
  Quote hoserator Quote  Post ReplyReply bullet Posted: 24 Jan 2022 at 11:01pm
This is a user forum and we can give you our opinions on how that order would go but you must call DS to find out. The options on your order are a couple of generations old so ..... ?
In the past, there were all sort of hardware arrangements on orders but so much has changed that the only way to be sure is to have a talk with them. Good luck and keep us posted so that we know how DS is arranging (or not) for special requests.
Smile
