Help with streaming gnfig
Post Date: 2020-07-18
Srr_Superman View Drop Down
  Quote Srr_Superman Quote  Post ReplyReply bullet Topic: Help with streaming gnfig
    Posted: 18 Jul 2020 at 4:19pm
Budget: Around 2400
Looking for a good streaming config not really pc gaming heavy because going to use elgado hd 60 pro capture card to stream My PS3, PS4 and future PS5 gameplay. Do know I want these in
32GB DDR4 3200MHz Digital Storm Performance Series
                         or
32GB DDR4 3000MHz Corsair Vengeance RGB Pro (RGB Light Bar)
1x GeForce RTX 2070 SUPER 8GB (VR Ready)
H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (Dual Fan) (Fully Sealed + No Maintenance)
Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes)
Digital Storm Performance Series (RGB Fans)
  Quote Cretae Quote  Post ReplyReply bullet Posted: 19 Jul 2020 at 3:58am
This configuration:
3259237
Does everything you wish for at $2343 after the discount. It will be a kick-a streamer. It's actually pretty cutting-edge. You don't need a 2070 unless you will be streaming at 1440p.
  Quote Srr_Superman Quote  Post ReplyReply bullet Posted: 19 Jul 2020 at 7:04am
in the 3259237 config is it ok to switch out the 1x SSD M.2 (512GB Samsung 970 PRO) (NVM Express) for the 1x SSD (500GB Digital Storm Performance Series) since its just storage and not change or cause any performance issue
Edited by Srr_Superman - 19 Jul 2020 at 7:18am
  Quote Srr_Superman Quote  Post ReplyReply bullet Posted: 19 Jul 2020 at 7:07am
and i dropped the 1x GeForce RTX 2070 SUPER 8GB (VR Ready) for the 1x GeForce RTX 2060 SUPER 8GB (VR Ready)
  Quote Srr_Superman Quote  Post ReplyReply bullet Posted: 19 Jul 2020 at 7:36am
Originally posted by Cretae
This configuration:
3259237
In this 3259237 config is it ok to switch out the 1x SSD M.2 (512GB Samsung 970 PRO) (NVM Express) for the 1x SSD (500GB Digital Storm Performance Series) since its just storage and not change or cause any performance issue and i dropped the 1x GeForce RTX 2070 SUPER 8GB (VR Ready) for the 1x GeForce RTX 2060 SUPER 8GB (VR Ready)
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Jul 2020 at 3:56am
The NVMe is not just storage, it's a technology that allows the SSD to run off the PCIe bus at 5 TIMES THE SPEED of the DS SATA SSD. It's a game-changer for everything you do from your operating system.
A 2060 SUPER will be great for 1080p monitors.
  Quote Srr_Superman Quote  Post ReplyReply bullet Posted: 20 Jul 2020 at 10:15am
Ok thanks Ive placed My order using this 3259625 config
This page was generated in 7.617188E-02 seconds.
