help with system
Post Date: 2008-03-17
bobski View Drop Down
  Quote bobski Quote  Post ReplyReply bullet Topic: help with system
    Posted: 17 Mar 2008 at 9:27pm
Im on a budget of $1600.00 should i go with 3 gig dou core E8400 or go with quad Q6600 2.4 gig .I want to game at the max for the money . open for sugestions
Edited by bobski - 17 Mar 2008 at 9:27pm
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 17 Mar 2008 at 9:45pm
personally id wait to see how the Q9xxx chips do. Though keep in mind that most games still only are opitmized to use 2 cores. Though id assume that will be changing in the next year or less. But if you must get a computer before that then id say go for the E8400 chip. In todays games its usually faster overall then the Q chip. As its better to have 2 CPUs running at 3GHz then having 2 running at 2.4ghz and 2 others just sitting idle.  Keep in mind also that the quad core is going to be pumping out more heat as well.
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 17 Mar 2008 at 10:27pm
I believe SunfighterLC has the right idea.  However, in many if not most games today, you're going to find yourself GPU limited with either of these chips. In the long haul, the quad cores will win out. The long haul may be a little longer than people expect.
Check out this link for some more data:
Edited by Bill the Cat - 17 Mar 2008 at 10:37pm
  Quote bobski Quote  Post ReplyReply bullet Posted: 17 Mar 2008 at 10:33pm
why would these chips be limited
  Quote bobski Quote  Post ReplyReply bullet Posted: 17 Mar 2008 at 10:35pm
why  do you think these to chips would be limmited and what do you sugest
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 17 Mar 2008 at 10:52pm
I think by GPU limited he is saying that both these CPUs are good for gaming, the difference between the two isnt very much. And if you were to get any major slowdown in gaming performance, it will most likely be because your graphic processor isnt doing well enough (GPU) and it wouldnt be because of these CPUs.
I could be wrong though, ive only been reading up on this tech stuff for about a month now. And yea the year or so for gaming to start using quad cores was a total guess. =P. If it takes longer oh well good for me because I want to use a E8400/8500 lol.
Honestly since you are on a budget, get the cheaper E8400 at least right now its 44 bucks less then the Q6600 (that could change, the E chips are VERY popular right now). That 44 bucks could be added to a GPU upgrade or just a savings overall.
Edited by SunfighterLC - 17 Mar 2008 at 10:54pm
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 18 Mar 2008 at 12:11am
Both choices bring with them additional costs, but I think overall, it's less expensive to use a dual core rather than a quad. I don't know that I'm the "average gamer" but I do feel that I gain advantages in using a quad core. I don't game on a pristine install of an OS with only Windows and the game I'm playing installed. I generally game in a Vista environment, and have upwards of 60 processes running at all times in addition to the game I'm playing. I don't really know why Vista needs so many processes running, but it does, and I am thankful to have the extra cores to take up the load.
Take what Sunfighter said about heat to heart though. Quads definitely require better case cooling than Core 2 Duo's. An 8400 on the other hand, if you plan on overclocking, needs better RAM to get best results than a Q6600 would, for example.
If you do not plan on overclocking at all, I would say the choice gets easier. In that case, even a quad fan like me has to admit the Duo makes more sense.
