High performance and low noise
Post Date: 2009-03-26
martyboeckman View Drop Down
  Quote martyboeckman Quote  Post ReplyReply bullet Topic: High performance and low noise
    Posted: 26 Mar 2009 at 11:16am
I am getting ready to pull the trigger and buy a new machine. I am looking that the system below. I have a couple of questions:
- What can you OC the CPU to with liquid cooling?
- Is it worth overclocking the video card? How much performance gain would I get? I chose liquid cooling on video card because the stock fan on the card is usually really loud (and I've had 3 GPU fans fail). I would guess that liquid cooling on the GPU would allow for some overclocking gains.
- I chose the solid state disk for noise and performance reasons. How loud are striped 10k raptors?
- I chose Zalman performance fans because Zalman has the reputation of being quiet - is that a good assumption?
Any other recommended tweaks for making sure I get a quiet high performance system?
Ticket Number: 263568
Total Price with Instant Savings: $3,881.00
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=263568
System Memory: 6GB DDR3 1600MHz Mushkin (Highly Recommended) (Digital Storm Certified)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: OCZ) (Ultimate Lightning Speed)
Video Card: 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
Extreme Cooling: H20: Stage 3: High-Performance Liquid Chilled FrostBite System For CPU & Single Video Card
Liquid Color:Green: Non-conductive High-Performance Fluid (Requires H20: Stage 3 Cooling Package)
Boost Video Card: Yes, Overclock the video card(s) as much as possible with complete stability
LCD Display: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Mar 2009 at 1:37pm
you have a better chance at maintaining lower temps and a higher OC speed with LC, however with the 920 we have seen it go to 3.8GHz both with air and liquid cooling.
As you said your self, GPUs go bad, if you LC the GPUs, anytime anything goes wrong with your GPU, you will have to send it in, so be prepared to be without your PC a month at a time, my recommendation is to drop the LC from GPU, it can turn out to be a nightmare. I have said this to others before and some after a 6 month hassle finally asked DS to remove their LC on GPU due to the headache it can be.
OCing your GPU is pointless but if you should ever need it we can help you with that, its real easy to do, but with a 295 I doubt if you will need it.
I don't think Raptor are noisy but there are much much faster better SSDs coming out, my advise is to go with vertex 2 when it comes out
Zalman is quiet but its not gonna be more quiet then the HAF fans, and if you need to crack them up they will be much more noisier.
here you go Ticket# 263680 --- Price: $2927 (To see this build click here) Price after current promotion $2752
System Memory: 6GB DDR3 1333MHz Mushkin (Highly Recommended) (Digital Storm Certified)
Windows OS: Microsoft Windows Vista Home Premium
army man View Drop Down
  Quote army man Quote  Post ReplyReply bullet Posted: 26 Mar 2009 at 7:34pm
dst4me does give good advice,i really didn't think of liquid cooling the gpu was a big hassle and i would agree i wouldn't want to be without my computer for a month if it was up to me.
life's to short to worry bout the small stuff
  Quote martyboeckman Quote  Post ReplyReply bullet Posted: 26 Mar 2009 at 8:18pm
When is the Vertex 2 coming out? Any idea?
I'll dump the liquid on the GPU, but I really would like the performance and quiet of the SSD.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Mar 2009 at 9:18pm
hopping to see the vertex 2 in about 30 days but you never know
