High Speed Network Port
Post Date: 2009-03-15
e06028 View Drop Down
  Quote e06028 Quote  Post ReplyReply bullet Topic: High Speed Network Port
    Posted: 15 Mar 2009 at 10:38pm
I am curious as to how my new machine was able to drop my ping in COD 5 from 72 to 45.  Don't get me wrong I love it, but I was telling someone that this happened and they claim and I quote "Honestly I don't get why you are getting a better ping, your internet connection makes your ping, not your computer".  I think this person is wrong but not sure why the ping fell by 27.  Any ideas?  I have the same internet service as well.
Oh and by the way, my frame rate in COD 5 went from 48 to 167.  You can imagine how my clan mates now hate my new computer, Smile.
Edited by e06028 - 15 Mar 2009 at 11:18pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Mar 2009 at 1:50am
so right now your old pc get 45 and your new one gets 72?
or you have not tested them next to eachother?
MrNanite View Drop Down
  Quote MrNanite Quote  Post ReplyReply bullet Posted: 16 Mar 2009 at 7:57am
Well, ping time is often a function of how fast your computer can answer the "ping" request.  On a slower/older computer, it takes longer for the system to "get around to it".  On a faster system, it's quicker to do.  Now, there *are* network cards with independent processors on them which could answer the ping a *WHOLE* lot faster.  But that same card can trick out the ping responses to make your machine look slower, when it really isn't.
BillDempsey View Drop Down
  Quote BillDempsey Quote  Post ReplyReply bullet Posted: 16 Mar 2009 at 12:23pm
There are a lot of elements that contribute to ping speed, not just your Internet connection speed. Part of the ping is the hardware responsiveness to signal changes, very true. One of those elements, though, is the efficiency and speed of the firmware in your network hardware. The firmware is basically computer code run by the network card processor (or your CPU, if it is motherboard-based) that filters and translates the electrical signal variations into meaningful data which is passed on to your computer as data packets. Slower firmware code will process the packets slower, resulting in a higher ping. Even on the exact same network hardware, small tweaks in the firmware can change packet transmit and receive significantly. I suspect your big ping gain is both a function of your faster CPU combined with more efficient code in the networking firmware on your new motherboard.
Those gamer-oriented add-on network cards have optimized network processors, optimized firmware, and they offload the work from the CPU. So, you get better pings plus a tiny increase in your frame rates. That's what makes them worth buying for FPS fans obsessed with every millisecond of ping.
