How do I check fluid level?
Post Date: 2009-08-10
slgilley View Drop Down
  Quote slgilley Quote  Post ReplyReply bullet Topic: How do I check fluid level?
    Posted: 10 Aug 2009 at 10:24am
I have the stage 3 liquid cooling.
How do I check the coolant level in the HAF 932,
What fluid do I need to replace it with, should I need to top it off, and
How do I replace the fluid?
It looks like it can all be done from the top of the case, but I want to be sure before I start pouring any kind of liquid into any hole.. :-)
Thanks,
Sean.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Aug 2009 at 3:51pm
you have to open the side panel and check your reservoir, if the level is low then you just unscrew the cap and add fluid.
the fluid they use is fluidxp but you can call them and ask them for the exact model.
