How does air get in?
Post Date: 2021-08-04
Nexinity View Drop Down
  Quote Nexinity Quote  Post ReplyReply bullet Topic: How does air get in?
    Posted: 04 Aug 2021 at 7:17pm
How does the air get in the pc if it has tempered glass in the front size where the intake fans are? Also does anybody know a good pc case under 100 dollars that is a mid sized case?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 05 Aug 2021 at 4:01am
If you're talking about the Lumos, it has filtered spaces between the panels all the way around.
There are dozens of perfectly suitable cases that fit your criteria. Just go shopping and read the reviews.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 05 Aug 2021 at 5:36am
There are air intakes designed into the case. Some are more free flow than others.
Like Cretae stated, there are way more mid size cases under $100. than you think. You have to have in mind what you intend to do and how important some things are, like air v liquid cooling, size of the various hardware and how they fit together, etc.
Enjoy the search.
Smile
This page was generated in 6.787109E-02 seconds.
