How hard to install aftermarket vid card fans?
Post Date: 2009-05-22
nomec View Drop Down
  Quote nomec Quote  Post ReplyReply bullet Topic: How hard to install aftermarket vid card fans?
    Posted: 22 May 2009 at 10:29am
As I have posted in other threads I have been having trouble with my Ultras while playing LOTRO, and I have no idea whether or not it is because of temps but it is the only possible thing I can think of.  I don't mind dropping $50 or so on some fans to install on them to help bring those temps down, and if it doesn't resolve my problems in the game and my nvlddmkm issues having cooler temps isn't a bad thing.
With that being said, is this hard to do?  I have never done it before and I am wondering if a noob would be able to do it Big%20smile  Also, what fans would I install onto an 8800 ultra?  Can anyone tell me where to look?
Thanks
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
Vista Home Premium 64-bit
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 22 May 2009 at 12:14pm
It's not hard. I'll pull you up some links, give me a sec.
Edit: Can you tell me what temps you are running at?
Edited by Zurginator - 22 May 2009 at 12:17pm
  Quote nomec Quote  Post ReplyReply bullet Posted: 22 May 2009 at 12:23pm
When I run GPU-Z one says like 74-76 and the other is like 68-72 when idle.  When I alt-tab out while playing games one is around 82-84 and the other is like 75-77.
Edited by nomec - 22 May 2009 at 12:25pm
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 22 May 2009 at 12:25pm
That's not bad at all. Those cards run hot, it's nothing to be worried about. And since you run SLI, it's hard to find another cooler that will fit them.
  Quote nomec Quote  Post ReplyReply bullet Posted: 22 May 2009 at 12:27pm
Well I am not sure then why I experience these problems.  Maybe I might have to just chalk it up to the fact that 8800s don't play well with 680i mobos.
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 22 May 2009 at 1:25pm
TBH, that's more likely than heat, lol.
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 22 May 2009 at 1:34pm
If you download EVGA's Precision app. you can monitor temps as you play. It overlays the temps on game screen. It would also let you view and control the GPU fan speeds. It also has a time vs. temp chart. (of course, it works with multiple GPUs)
Blown out your fans and grills lately?
Edited by Bill the Cat - 22 May 2009 at 1:36pm
  Quote nomec Quote  Post ReplyReply bullet Posted: 22 May 2009 at 2:06pm
Yeah I have done that, so I'm not sure what the deal is!
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
