how to check my overclock speed?Post Date: 2012-01-21 |
kane860
Senior Member Joined: 09 Dec 2011 Online Status: Offline Posts: 612 |
Topic: how to check my overclock speed? Posted: 21 Jan 2012 at 3:25am |
Can someone walk me through the process of checking what my current overclock speed is at? What programs to download or use, what to run while what ever else is monitoring or what not.. I would appreciate it.
System:
HAF X942 / i7 3930k 6-core cpu / ASUS P9x79 Deluxe MOBO 16gb DS ram / Corsair 1050HX PSU / Two - Intel 320 series 120gb SSD's WD Caviar Black 1TB HDD / GTX570 2.5gb GPU / Noctua D14 Cooler |
Dranzogger
Newbie Joined: 22 Jul 2011 Online Status: Offline Posts: 72 |
Quote Reply Posted: 21 Jan 2012 at 1:21pm |
I use CPU-Z.
maxyme
DS Veteran Joined: 14 Aug 2010 Online Status: Offline Posts: 1514 |
Quote Reply Posted: 21 Jan 2012 at 1:56pm |
Make sure you run something that stresses your CPU though like prime95 because DS uses an overclock that only goes on when it is neeeded.
Steam:pcmaster160
Quote Reply Posted: 21 Jan 2012 at 9:21pm |
for checking oc/vcore/mobo/rametc: CPU-z
for checking gpu stuff and ocing gpus and setting fan speeds: MSI Afterburner there are many apps to stress test your system, I like fah: follow my fah guide here when checking your oc, you want to make sure the cpu is under load/stress. the same when checking temps for parts, you want to make sure that part is under stress and then you want to max loud temps lower then 85c. |
Quote Reply Posted: 22 Jan 2012 at 7:08am |
kane860....Another voice heard....A quick check is to run CPU-Z while running Windows Experience Index, under Computer > Properties.
It's not an extended stress test but gives you a quick peek at vcore and oc speed when stressed. DST's fah guide is great for seeing what's what under load, the health of the chips. Good to run at least once to test.
Edited by bprat22 - 22 Jan 2012 at 7:08am |
kane860
Quote Reply Posted: 22 Jan 2012 at 10:42am |
thanks guys, I will check those out
System:
kane860
Quote Reply Posted: 22 Jan 2012 at 12:51pm |
So I have CPU-Z open and I actually just tried to run Prime95. What am I supposed to notice in CPU-Z that will tell me what my overclock is it? Under the CPU tab, I do see Clocks (core#0) and I do see the core speed changing and it went up to 4300 mhz which sounds like that is what I should be looking at since DS told me my overclock was set to 4.3ghz. So is this correct then? |
System:
kane860
Quote Reply Posted: 22 Jan 2012 at 12:55pm |
also is there any way for me to control my fans, like if I wanted to turn up my fans speeds?
System:
Quote Reply Posted: 22 Jan 2012 at 2:18pm |
Yep, you got it. The cpu-z core speed is Oc speed, in your case 4.3 and farther up is the core voltage, vcore, which is probably 1.4 +/-. SpeedFan and MSIAfterburner are used for fan control. I messed with them but my temps were great so I left them alone. They're busy programs and take a little effort to tweek but worth knowing.
kane860
Quote Reply Posted: 22 Jan 2012 at 3:01pm |
there is no other way to control my fans other than download those programs?
System:
Tidgxor
Quote Reply Posted: 22 Jan 2012 at 3:18pm |
Which fans are you wanting to control? Depending on the fan and your setup there is a good chance you wouldnt be able to control the RPM of a fan (at least not via a program). Other things like GPU fans are easy.
Edited by Tidgxor - 23 Jan 2012 at 1:48pm |
kane860
Quote Reply Posted: 22 Jan 2012 at 3:49pm |
I was curious if I could control the RPM's of my top exhaust fans, the side panel fan, the front fan and the rear exhaust fan.. so I guess I want to know if I can control all my fans lol
Also, what are normal temps for CPU? I did stress test with Prime95 and my high temp is 77 degrees celcius (170 degree fahrenheit).... is that good, bad, normal, average???
System:
Quote Reply Posted: 22 Jan 2012 at 11:46pm |
Your case fans you can't control, any fan connected to the mobo can be controlled.
Whats your max load temp with haf's smp? |
kane860
Quote Reply Posted: 23 Jan 2012 at 9:46am |
DST what is "smp" ? .... under load, my max temp was 77c
System:
kane860
Quote Reply Posted: 24 Jan 2012 at 10:32pm |
so is 77c max temperature under load good or bad?
System:
Quote Reply Posted: 25 Jan 2012 at 12:13am |
smp is the name of a cpu client for fah, it uses the cpu to do heavy calculations and puts all cores to work like they were mules, so you were running smp and it was green and your max temp was 77c? if so that is good temps, remember for cpu and gpu we are looking for temps under 85c.
