How to enable wireless in a Ethernet pc
Post Date: 2019-03-27
Lucidd View Drop Down
  Quote Lucidd Quote  Post ReplyReply bullet Topic: How to enable wireless in a Ethernet pc
    Posted: 27 Mar 2019 at 6:00pm
I got my new lynx pc but I can’t conenct to the wireless WiFi so I’m guessing it was disabled. The only adapter option I have is a Ethernet which I don’t have. Can anyone tell me how to enable a wireless connection.. my bios is MSI.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 27 Mar 2019 at 8:27pm
I don’t believe the motherboards they use for Lynx come equipped for WiFi.    You just need to get a USB WIFI adapter dongle to plug into a USB port to connect to your home WiFi network.   Wired Ethernet connection to you network would be better, but a USB WiFi adapter dongle can be very inexpensive...like $15-$50 at Amazon, Newegg or bestbuy...
