How to keep a computer running fast over time?
Post Date: 2010-08-21
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Topic: How to keep a computer running fast over time?
    Posted: 21 Aug 2010 at 11:47pm
What do you guys recommend to keep computers running fast over time? There are tons of programs that claim to do this but i have learned from experience many actually slow down the computer. I know CCleaner is great but is there anything else that should be done to keep it running fast?
Ch3ssplay3r View Drop Down
  Quote Ch3ssplay3r Quote  Post ReplyReply bullet Posted: 22 Aug 2010 at 12:16am
Back up your important files and reinstall windows every six months or so, or when you are experiencing massive slowdowns. There's nothing really performance improving like a fresh install.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 22 Aug 2010 at 12:39am
so true, either backup everything on dvds(which you should do anyway) and reformat when you get bogged down
a wonderful quickfix is a double dose of ccleaner(and its registry cleaner) and defragging
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 22 Aug 2010 at 11:55am
and, turning off virtual ram/paging file I've found also gives somewhat of a performance boost. make sure you have more than enough physical ram first though.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote maxyme Quote  Post ReplyReply bullet Posted: 22 Aug 2010 at 9:36pm
A fresh install is ideal but i'm mostly looking for ways around it because i install tons of programs and its a huge pain to reinstall them. by a double dose do you mean run it twice? What does the paging file even do?
dranza View Drop Down
  Quote dranza Quote  Post ReplyReply bullet Posted: 23 Aug 2010 at 3:34am
No, you don't need to run it twice
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 23 Aug 2010 at 8:59am
best way is to never have a crash, freeze up, lose power, and to not install extra programs.. all those stupid sidebars, toolbars,. ect slow things down
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 23 Aug 2010 at 9:24am
my double dose i actually meant several times, ccleaner will find new registry problems afrter several runs, so i find it best to run the cleaner with no free space wipe, then the reg cleaner, then back and forth, until nothing new is found, then restart and do it again, then defrag and restart
but yes, as justin said, being a minimalist and staying away from bloatware will keep you running faster longer
