How to refill Velox water cooling
Post Date: 2020-12-09
Dgaleman View Drop Down
  Quote Dgaleman Quote  Post ReplyReply bullet Topic: How to refill Velox water cooling
    Posted: 09 Dec 2020 at 12:18pm
I have a velox system that is over three years old. Unfortunately, it started leaking from where the CPU is mounted. I was luckily able to patch up the leak, but I lost too much coolant (about half). I did not think much of it, until my CPU would shut down my computer due to overheating. I have ordered some more coolant, but I am having difficulty determining how I can open the coolant holder due to the limited space. I have contacted DS, but have yet to get a call back, so I figured I would attempt to see if anyone here knew how to refill their Velox system.
Thank you for reading, and have a safe and happy Holiday season!
Dave
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Dec 2020 at 4:00am
I have seen it said that a 6mm Allen wrench with the short 90 degree bend to it does the trick.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 10 Dec 2020 at 11:39am
Happy Holiday Season to you also. Smile
What cooling system do you have?
Like Cretae stated, you need a 6mm hex (Allen) key to unscrew the top caps if you have the EK reservoir. (HydroLux PRO) Alex has stated that they are also using Alphacool and don't know about those reservoirs.
This page was generated in 7.800293E-02 seconds.
