How to replace optical drive on DS laptops?
Post Date: 2014-10-18
thenardier View Drop Down
  Quote thenardier Quote  Post ReplyReply bullet Topic: How to replace optical drive on DS laptops?
    Posted: 18 Oct 2014 at 6:50pm
I'm considering a purchase of a DS laptop, but I need to know if the optical drive can be easily replaced.
Can anyone post instructions on how to do this? Would there be any difference in how to do this amongst the different laptop models (i.e. Krypton, Behemoth, etc.)?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Oct 2014 at 2:53am
Hi thenardier... Welcome to the forums.
For most, flip over the laptop and just below the optical drive is a small cover you'll remove. Once off, a couple of small screws removed and the drive can be slid out the side.   The manual for the laptop has an Upgrade section that shows how to access the various parts.
Hope this helps.
Roykirk View Drop Down
  Quote Roykirk Quote  Post ReplyReply bullet Posted: 19 Oct 2014 at 2:13pm
thenardier,
It appears to be a pretty simple process according to the service manual.
Just remove one of the bottom plates, remove a screw that holds the optical drive in place, and push it out and put in the new one by reversing the process.
