Hydrolux Control Center v1.9 not connecting
Post Date: 2023-07-23
Ragingfetus View Drop Down
  Quote Ragingfetus Quote  Post ReplyReply bullet Topic: Hydrolux Control Center v1.9 not connecting
    Posted: 23 Jul 2023 at 3:58pm
Ill be brief. Its located on COM3 but the v1.9 and v1.7 wont connect. I tried COM1 - 4 just to be make sure. I believe the issue is a windows update over-rode the settings and set the parity and bit rate to the default as i cannot think of any other reason it wouldnt connect. What is the default settings of the COM port when coming from the factory? This way i can check to ensure they match. Other than that i dont know why it cant see the HL board. On the scale of issues this is very small so i am not concerned at the moment. THank you for any input.
Have a blessed day
  Quote hoserator Quote  Post ReplyReply bullet Posted: 25 Jul 2023 at 6:58am
Call DS  to report the problem. They can fix you up.
I was never able to work with mine. Every time I opened it the pc crashed!
