I need a Little Help
Post Date: 2008-06-21
mar1o8 View Drop Down
  Quote mar1o8 Quote  Post ReplyReply bullet Topic: I need a Little Help
    Posted: 21 Jun 2008 at 9:38pm
Okay Well i have to... not so hot.. computers now i guess you could say. But i do a lot of traveling so i'm looking into getting a laptop, Is there anyway i could keep it under 2K but still play call of duty 4 and all of those top games and smoothly?
  Quote mar1o8 Quote  Post ReplyReply bullet Posted: 21 Jun 2008 at 9:46pm
BTW any comments will be fine because i don't know a lot about laptops.. more of a desktop go all the way kinda gamer, so any knews is goodBig%20smile
shaba_levi View Drop Down
  Quote shaba_levi Quote  Post ReplyReply bullet Posted: 22 Jun 2008 at 4:03pm
Same...the thing about laptops is you almost always have to "settle for less" so to speak.
Laptops can get very hot very fast, i would not recommend playing any high end game for any extended period of time.  For me personally, laptops are for buisness only and are designed for work on the go, in short spurts.
But like harley said, im sure DS will hook you up
DS Rig:
750W PS
Quad Q9450 2.66GHz
Nvidia 780i 1333FSB
4G DDR2 800MHz
750G HDD1
320G HDD2
GeForce 9800GTX 512Mb
HT Omega Claro+
Vista Premiumx64
  Quote mar1o8 Quote  Post ReplyReply bullet Posted: 23 Jun 2008 at 2:03am
yeah i thought so to.. is there anyway to fix the getting hotter part?
Deathwest View Drop Down
  Quote Deathwest Quote  Post ReplyReply bullet Posted: 23 Jun 2008 at 3:17pm
mar1o8
If you have to go with a lap top I have had vary good luck with a
laptop cooler. I use one that plugs into a USB port and i see
a big difference in my FPS in World of Warcraft
I also use a laptop make for Autocad a Dell M65 it works
nice for gaming but is no Desktop!
Hope this helps
Harry View Drop Down
  Quote Harry Quote  Post ReplyReply bullet Posted: 23 Jun 2008 at 4:29pm
Originally posted by Deathwest
mar1o8
Hope this helps
What kind of cooler do you use?
Cool Master HAF 932
Core i7 965 DSO OC
Water cooled CPU
ASUS Rampage II Extreme
6 GB DDR3 1600 OCZ
1000 W Corsair HX
GTX 470
300 GB Raptor
tera 7200rpm
Windows 7
  Quote Deathwest Quote  Post ReplyReply bullet Posted: 23 Jun 2008 at 10:44pm
I have bought two, one from Circuit City and one from Staples (can't remember).  One for home and one for travel.  They both work well, the one I have for traveling is a Targus and it works great this one has 2 fans and the other has 3 fans  HTH
The brand does not matter, you get what you pay for .
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 23 Jun 2008 at 11:22pm
http://www.digitalstormonline.com/comploadsaved.asp?id=157004
solid launchpad, the case is considerably smaller than a lot of todays mainstream cases, fair price and a lot of bang for your buck
  Quote mar1o8 Quote  Post ReplyReply bullet Posted: 27 Jun 2008 at 6:32pm
deathwest do you know the model number or anything and the brand so i can look those up
This page was generated in 0.1132813 seconds.
