I need a little help
Post Date: 2008-10-05
wiacekc View Drop Down
  Quote wiacekc Quote  Post ReplyReply bullet Topic: I need a little help
    Posted: 05 Oct 2008 at 6:59pm
I am looking into getting a desktop and i am fairly new to computer gaming.  I am looking for a rig that will be useable for around 3 to 4 years.  My budget is abour $3300-$3700.  What is the best set up for that price.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 7:03pm
Welcome aboard
what resolution are you going to be gaming at and are you looking for a system that will let you run at that resolution at hi settings?
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 7:14pm
i am guessing that i can hook it up to my tv.  that is a 1080p samsung.  i would say that i would look to run at max resolution.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 7:30pm
ok, q9650 version:
here you go Ticket# 190956 --- Price: $3487 (To see this build click here)
Processor: Intel Core 2 Quad Q9650 3.0GHz (1333MHz FSB) (12MB Cache)
Card Reader: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 260 896MB (Includes PhysX Technology)
TV Tuner: - No Thanks
Internal Lighting: Blizzard Internal Lighting (Red Edition) (Cold Cathode Tubes)
Modifications: - No Thanks
Protection: - No Thanks
LCD Display: - No Thanks
q9550 version:
here you go Ticket# 190958 --- Price: $3211 (To see this build click here)
I did not add a sound card, if you are big on sound then add a razer sound card to it.
both of those will run what ever you got.
the difference is that with the q9650 you can expect your pc speed to be around 3.8 to 4.0GHz.
with the q9550 you can expect your pc to be around 3.4 to 3.6GHz.
use the first HDD for OS/apps and games and use the second hdd for media/personal files.
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 7:42pm
As far as the 64-bit OS goes, will i encounter any program conflicts with that.  Would it be a better idea to go with the 32-bit and use the PAE option?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 7:48pm
no at best a 32bit can only access total of 4GB
you have total of 5.8GB of ram in there. no 32bit can use it.
also if you read about PAE, you will notice it will limit to 2GB which actually in most cases gives you less ram
64 bit will see all of that and use it
only problems you may have with vista 64bit is very old games may not work on it.
I have been watching/testing vista 64 bit for a while now and I have found it to be very good, XP 64bit was a nightmare, vista 64 I think is gonna be the OS that will make the move to 64bit easy, for xp lovers like you and me
Edited by DST4ME - 05 Oct 2008 at 7:49pm
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 7:53pm
I also have some "special" needs with this computer.  I will be moving to Germany and was wondering what size of converter will i need if any.  Are the power sources 100/220v?  Would it be possible to get a Europian plug?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 7:55pm
wiacekc if you call DS I'm sure they can work that out for you.
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 8:18pm
As for the near future I am assuming that with your set ups I will not need to upgrade at all.  Am i right in thinking that?  As far as sound cards go, I was planning on using my home theater system.  Is there a big differance between the cards you offer?
On a side note I was looking at Vigor, Falcon NW, and Velocity Micro.  Your level of advice and service won me over.  You have a customer for life.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 8:27pm
Thats great to hear wiacekc, only problem is that I'm a customer like and I don't work for DS
Just like you I too checked out fwn, vigor, vm and many more, each has their own problems or combination of below:
too expensive for no reason, same parts cost more.
bad customer svc.
lack of tech knowledge
lack of customization
lack of customer satisfaction
then I found DS, this place is great, I love it so much, I'm hanging out here and helping others to get the best quality PC for the best price
but trust me DS is very happy to have you onboard.
well this motherboard offers you a 7.1 audio, which for somebody like me is good enough.
out of the cards we have, as I suggested before I would go with the razer, its got the least problems and lots of features for people who are big on audio.
upgrade-wise, you can always change your CPU with a faster one down the road (highest you can get is a qx9770 3.2GHz, this chip overclocks great)
you can always add a third graphic card but I gave you 2 so I'm not sure why you would need 3 but if the situation ever comes, your PC can hangle 3
but none of those are needed, it that was my PC I would not upgrade it for 2 years at-least.
hope that helps
Edited by DST4ME - 05 Oct 2008 at 8:28pm
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 8:32pm
thank for the advice.  it made this much easier
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 8:34pm
NP, its my pleasure
I forgot to mention that can add many more harddrives to that pc, it holds a total of 11 drives. (harddrives, cd/dvd drives, etc.)
Edited by DST4ME - 05 Oct 2008 at 8:35pm
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 8:42pm
it seems that this thing is awesome.  what do you think about the SS hard drives?  worth the money?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 8:45pm
Right now I would say no, a velociraptor is great, when the prices drop and the sizes get bigger and its been out in the market for a longer period then it would be good.
That rig is a beast
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 9:02pm
what are your thoughts about keyboards?  is there a reason to buy a "gaming" one?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 9:05pm
That is personal preference, I don't play games on pc so I'm not the best person to ask.
my advise is that you use a what ever you have now for a week or two and figure out what types of option you would like to have, that way you know what you want
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 9:13pm
would there be any reason the upgrade the cooling unit to include the GPU's?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 9:25pm
if you are gonig to OC the gpu then for sure if not then no
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 9:31pm
if i OC them will it make a noticable differance.  the cost of the next level cooling unit is kind of high
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 9:40pm
trust me when I say its not for you OC GPU is for GPU enthusiast
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 11:18pm
Might be a little off subject but please bare with me.  I am quite new to compter gaming so excuse me if i dont know what i am talking about.  what is Nehalem?  should i wait to get on.  is it that much better than current CPU that i have in this build?  Sorry again, i am new.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 11:26pm
OK, if you look at the 2 builds I recommended, you will see each has a CPU. first one has the Q9550 and the second one has the Q9650.
both of those CPUs are from the penryn family, Nehalem(core i7) is going to replace penryn.
the chip is a real quad core, for multitasking and computing its a big difference, for games not that much, but over all its a better chip and it will cost less.
I'm waiting for it, it should be out in Nov.
ask any questions you like, there is no stupid question and we all had to start somewhere, its good that you ask questions
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 11:34pm
i am currently in Afghanistan so i will have some time before i buy.  will there be any thing out around the march 09 time fram that will be out that will "outdate" what you showed me?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2008 at 11:40pm
well nehalem will pretty much make penryn outdated but that does not mean penryn won't be good cpu till end of 2009 atleast.
Lawdog View Drop Down
  Quote Lawdog Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 2:28pm
Computer hardware is being upgraded at a phenomenal rate.  IF the auto industry was upgrading as fast as the computer industry you'd have a car that does 300mph and would go 200 miles on a gallon of gas by now.  By March some things will no longer be bleeding edge but will in no way be outdated or obsolete.  There is no reason a the computer you are looking to buy shouldn't last you 3-4 years with little to no modifications.  Although at the end of that time frame you may not be able to run things on max settings.
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 3:49pm
Thanks for the input.  It's amazing how much I learn in these DSO forums.  And its good to get a different view on things.  Sorry DST4ME.  Any other thoughts about the build that is in the thread?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 5:20pm
not sure why you are apologizing but I'm glad you are asking and learning
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 5:37pm
would there be any differance if i was to upgrade to the 4GB 1600MHz platinum from the 1333MHz. does the MHz speed make that big of a differance.  there is a big price jump to 2000MHz,  would a casual gamer like me notice the differance, assuming all chips were 4GB?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 5:43pm
no, the ram speed will help you OC better but the 1333 will allow you to go 5.4GHz which a mombo can't handle.
also if you don't OC or for any reason the PC is not OC any amount of ram speed over he FSB can't be used and is a waste.
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 5:53pm
what is the differance between DDR2 and DDR3?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 6:12pm
ddr2 has 4 internal backs while ddr3 has 8,
drr2 tops at 1066, drr3 right now tops at 2000.
have a look here, it will explain lots of stuff
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 6:14pm
I believe there is lot more difference then that
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 6:16pm
DDR3 is more efficent and for the most part can be faster.
Though DDR 3 is a lot like quad core processors, their time just hasnt come yet where computers can utilize their full potential yet.
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 6:17pm
the new chip Nehalem will, but I think that Westmere will be the first to really rip into it.
  Quote wiacekc Quote  Post ReplyReply bullet Posted: 07 Oct 2008 at 6:21pm
do you know the price of the Nehalem chips?  the more i hear the more i think i want one
