I need help choosing a pc
Post Date: 2018-12-31
QwyC View Drop Down
  Quote QwyC Quote  Post ReplyReply bullet Topic: I need help choosing a pc
    Posted: 31 Dec 2018 at 4:40am
So im new here and i want to get a pc.
I really dont know what to choose so i could use some help.
I want a pc that can stream and play games decently.
Like streaming and that the game plays at minumum 100 fps.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 31 Dec 2018 at 4:54am
A lot depends on your budget, the games you play and your monitor resolution.   The last two determine the graphics card. The more demanding games and the higher the resolution means higher end graphics card.
The Vanquish line is definitely the best bang for your buck.   The level 3 is minimum for high end graphics on a 1080p monitor,   You won’t get 100fps on all games but you probably don’t need it on a 60 hz monitor.    The level 4 with its RTX 2070 will max anything out there on a 1080p and most 1440p and give you headroom for streaming.
Edited by bprat22 - 31 Dec 2018 at 4:54am
