i need help
Post Date: 2010-07-31
kruger135 View Drop Down
  Quote kruger135 Quote  Post ReplyReply bullet Topic: i need help
    Posted: 31 Jul 2010 at 10:59pm
Hello every one if you cant tell im very new at this and im wondering if some one can help me out with how i should start building a gamming pc. All i really want is a pc that is fast and will run games without freezing up or crashing. So i was wondering if some one can point me in the right direction of what the best parts are for the type of pc i want im on like a 2000 dollar budget so if you guys can help me build a gaming pc under 2000 dollars i would greatly appriciate it thank you
 yes i know im a noob dont rub it in
Im%20with%20Stupid
WardTheSteak View Drop Down
  Quote WardTheSteak Quote  Post ReplyReply bullet Posted: 01 Aug 2010 at 12:31am
Build yourself, or buy from here?  I would suggest buying from here, price difference isn't that big and you get a nom nom nom 3 year warranty right off the bat.  427289 Here's a config ready to pwn, if its too expensive for you change the 80gb intel ssd to a 40 gb.  Basically you're gonna use the ssd for your operating system, apps, and the main games you are currently playing.  Everything else will go to the 500gb data drive.  Also what resolution is the monitor you're going to be playing on?
rholyrag View Drop Down
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 01 Aug 2010 at 6:18am
Welcome to the forums kruger135!
You may want to post in the config section.  The guys there will give you the best bang for your buck, and then you can determine which is better for you, build your own or buy from DSO.  As WardTheSteak pointed out, price difference isn't that big and you get a great 3 year warranty.
This page was generated in 5.371094E-02 seconds.
