I need some advice on some specs
Post Date: 2007-11-26
Help on Deciding View Drop Down
Guest
Guest
  Quote Help on Deciding Quote  Post ReplyReply bullet Topic: I need some advice on some specs
    Posted: 26 Nov 2007 at 4:44pm
HI, I'd like some advice on this config. I'm trying to make a good gaming rig and this is what I've come up with so far. I'm deciding if i should get two 150gb digital raptors instead of 1 and a 400gb western digital. if i get two i'd lose memory but it would read and write very quickly. Also do you think i would need liquid cooling for this or should i just stick with the current cooling spec? Any help would be much appreciated. Any other tips would be nice also. :)
Case: Digital Storm Twister EXTREME (Black Anodized Aluminum Finish)
Power Supply: 850W SilverStone Decathlon (Dual SLI Compatible) (Model: DA850) (Silent)
Processor: Intel Core 2 Quad QX6850 Extreme 3.00GHz (1333MHz FSB)
Motherboard: nVidia 680i LT Core 2 Quad (By: eVGA) (nForce 680i SLI)
Memory: 2GB DDR2 Corsair at 800MHz Dominator (Dual Channel) (High-Performance)
Floppy / Card: - No Thanks
Hard Drive 2: 400GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Raid Option: Setup hard drive 1 and 2 in a Raid 0 Stripe (Read and Write Performance Boost)
Hard Drive 3: - No Thanks
Video Card: 2x SLI Dual (nVidia GeForce 8800GTX 768MB (By: eVGA) (PCI-Express)
TV Tuner: - No Thanks
Sound Card: Creative Labs Sound Blaster X-Fi XtremeGamer (Up to 7.1 Channel) (Recommended)
Physics Card: - No Thanks
Cooling: Air Cooled Stage 2 (Silent Artic Cooling Heat-sink (Copper Heatpipes)
Round Cables: Enhanced Interior Air Flow (Optical Drive & Floppy Cables (Blue Edition)
Protection: - No Thanks
Benchmarking: 3D Mark 2006 Advanced Edition (By: Futuremark) (Pre-Install and apply updates)
Pre-Install Game: - No Thanks
LCD Display: - No Thanks
Price $4,486.00
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 26 Nov 2007 at 4:48pm
It will run fine on air with the case you selected.
You might want to invest into a 680i A1 because you will get better overclocking results with it.
If money isn't a problem and if you want all the performance you can get than raid 0 raptors... You can always get an external HDD later if needed.
