i7 920 vs i7 940 cooling/overclocking
Post Date: 2009-05-23
Elmpe View Drop Down
  Quote Elmpe Quote  Post ReplyReply bullet Topic: i7 920 vs i7 940 cooling/overclocking
    Posted: 23 May 2009 at 9:08am
This forum is really helpful.
If I order a build with stage 2 air cooling is the expensive of going with the i7 940 over the i7 920 worth it in terms of overclocking potential?  In other words will I be wasting money on a more expensive chip because I'm afraid of liquid cooling maintenance?
Thanks
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 23 May 2009 at 9:50am
No, The 940 at the same speed as the 920 will not run any cooler.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 May 2009 at 10:16am
your OC is dependent more on the chip itself then anything else, you can end up with a 920 that OCes better then the 940 or vise versa.
B@d//j0ke View Drop Down
  Quote B@d//j0ke Quote  Post ReplyReply bullet Posted: 23 May 2009 at 3:55pm
Yeah, what DST is saying is its kinda the luck of the draw, some i7920s OC better then other i7920s.
But regarding heat the 920 and 940 are the same chip, just factory clocked at 2.66 and 2.93 respectively. so if you force a i7920 to run at 2.93 it will run as hot as the 940, no hoter.
Edited by B@d//j0ke - 23 May 2009 at 7:15pm
  Quote B@d//j0ke Quote  Post ReplyReply bullet Posted: 23 May 2009 at 4:01pm
However, reagerding Liquid cooling(LC) maintenance there really is not any. LC is a great option for cooling, and all it takes is for you to check the liquid every so often and top it off when needed. (Like coolent in a car)
However LC is more expensive, and if you dont have the budget to include LC OR if that money could be used to get a better video card or RAM then go with Air cooling.
I suggest the "Noctua nh-u12p"  It is a great air cooler!
