IC help
Post Date: 2011-12-28
hotshot146 View Drop Down
  Quote hotshot146 Quote  Post ReplyReply bullet Topic: IC help
    Posted: 28 Dec 2011 at 7:34pm
I just got my DS computer and I had stage 6 IC installed on it. What type of maintance will I have to do on it and how ofter do I have to do it?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Dec 2011 at 7:38pm
Just check your reservoir's level and if it gets close to half way full, fill it back up.
you can use distilled water or feser fluid is I think what they use.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 28 Dec 2011 at 8:54pm
Do not use Kool-Aid as a coolant. Trust me. Big%20Smile
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 Dec 2011 at 9:05pm
Nothing beats the voice of experience.lol
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 28 Dec 2011 at 11:07pm
But I need a place to store my Kool-Aid. Cry
Edited by hotshot146 - 28 Dec 2011 at 11:09pm
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 28 Dec 2011 at 11:15pm
Be that as it may, try to resist putting it inside your computer. Doing so may cause a large, animate, glass jug to burst out of your rig and destroy your room while screaming success. True story, just don't do it.
Hahaha
Edited by Tidgxor - 28 Dec 2011 at 11:15pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Dec 2011 at 12:07am
Don't try bear either
