If I order ODE Level 4....
Post Date: 2011-06-09
Syph3n View Drop Down
  Quote Syph3n Quote  Post ReplyReply bullet Topic: If I order ODE Level 4....
    Posted: 09 Jun 2011 at 1:07am
So if I order the ODE level 4 would DSO humor me by turning the OC down to 4.5ish? also would the 850 PSU be sufficient for SLI 570s?
bishamon View Drop Down
  Quote bishamon Quote  Post ReplyReply bullet Posted: 09 Jun 2011 at 1:17am
The thing with that system is that it's prepackaged, so off the bat I doubt it. What you could do is call them once you get your system, and they could maybe run you through your BIOS and help you through turning down the overclock (they save your logs I think).
Edited by bishamon - 09 Jun 2011 at 1:18am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Jun 2011 at 2:17am
I don't think they will make any adjustments while its at DS.
the 850w hx or ax can run sli 580 np, the tx is not known for the same performance, I would not personally use the tx for sli 570.
Oversoul87 View Drop Down
  Quote Oversoul87 Quote  Post ReplyReply bullet Posted: 09 Jun 2011 at 11:37am
I called and they said they would turn down the overclock on my level 4. What has me concerned, is now the "pre-built" none configureable computer, has the parts changing on the specifications page after I have ordered, and its supposed to be at stage 5. Am now waiting patiently so I can call and ask what is up this morning.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Jun 2011 at 11:42am
What parts changed? you mean after you ordered the parts on your order changed or after you ordered the ode had new parts that it didn't have when you ordered.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 09 Jun 2011 at 11:44am
Hi Oversoul87,
They must have sold out the first run of the Level 4 ODE to be making the changes. It would appear that each run of ODE computers will have their own particular equipment. I doubt they made any equipment changes to your computer unless they had equipment failures.
  Quote Oversoul87 Quote  Post ReplyReply bullet Posted: 09 Jun 2011 at 11:47am
I mean the ODE changed base parts, it now has the 590, instead of sli 470s, the overclock has been lowered from what was up to 5ghz, I think was a stage 3 oc, and of course the motherboard change. Am just curious as to what I will be receiving :p
  Quote FrankW Quote  Post ReplyReply bullet Posted: 09 Jun 2011 at 11:47am
Hi DST4ME,
The new run of ODE level 4 will have the Sabertooth MB and a 590 video card according to the latest specs they are posting.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Jun 2011 at 11:48am
Oh really, well you don't want the 590 anyways, so you got lucky and the extreme is a much better mobo than saber.
