IN need of a new PC!!! please help with specs
Post Date: 2008-09-13
tang526 View Drop Down
  Quote tang526 Quote  Post ReplyReply bullet Topic: IN need of a new PC!!! please help with specs
    Posted: 13 Sep 2008 at 6:13pm
Hello everyone, i am new to the forums!
i'm in need of a new pc FOR school plus my current computer is old and is pentium 2 with dial up lol and i saw an ad for digital storm so i decided to check it out and see what i can work with.
i tried to max out the ram and hdd as much as i could with my budget.
Suggestions are highly welcome ( i dont know much about computers and
i plan on working photoshop, some gaming (wow, starcraft and possibly RA3), watching films, and maybe tweak with some video editing and audio engineering
please tell me if i need to change something.. i want the pc to run flawlessly
also, i have a question about overclocking option.. do they overclock for me?
and the tweaking of the OS, does this mean they make all those useless services take less cache or something? please explain and THANK YOU
HERE ARE THE SPECS.
Total Price with Instant Savings: $2,057.00
Chassis: Digital Storm 750Si
Power Supply: 550W Corsair HX (Dual SLI Compatible) (Silent Edition)
Processor: AMD Phenom 9750 (2.4GHz) (Quad Core) (2 MB Cache) AM2+
Motherboard: NVIDIA 750a SLI (Chipset: nForce 750a SLI)
System Memory: 4GB DDR2 Corsair at 800MHz Dominator DHX (High-Performance)
Card Reader: - No Thanks
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Optical Drive 2: DVD-ROM/CD-ROM (DVD Reader 16x / CD Reader 40x)
Video Card: NVIDIA GeForce 9600GT 512MB (Includes PhysX Technology)
TV Tuner: - No Thanks
Extreme Cooling: Air Cooled Stage 3 WindTunnel (Copper Heatpipe Heatsink & Additional Case Fans)
Modifications: - No Thanks
Protection: - No Thanks
LCD Display: Acer 17 inch (Black Edition) (High-Value Display)
Warranty: 4 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Sep 2008 at 6:38pm
here you go $2042
Chassis: Digital Storm 850Si
Power Supply: 650W Corsair HX (Dual SLI Compatible)
Processor: Intel Core 2 Quad Q9450 2.66GHz (1333MHz FSB) (12MB Cache)
Motherboard: NVIDIA 780i Core 2 Quad (Chipset: nForce 780i SLI)
System Memory: 4GB DDR2 OCZ at 800MHz
Hard Drive 1: 250GB Western Digital (16MB Cache) (7200 RPM) (SATA)
LCD Display: - No Thanks
search around for your lcd and keyboard and you should find a better price, try newegg
on your own system change os to what I have it in my config
drop your sound card and one of your dvd drives if you don't really need them.
also you forgot your ticket number
Edited by DST4ME - 13 Sep 2008 at 6:41pm
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 13 Sep 2008 at 6:58pm
If you can stretch that budget by ~$100, here's a configuration that should cover all of the bases well for you.
  Quote tang526 Quote  Post ReplyReply bullet Posted: 13 Sep 2008 at 8:01pm
well i'm keeping the sound card but do you think the extra hdd is not a good idea?
heres my Ticket Number: 182569
does chassis really make a large difference?
and the power supply, more watt is better right?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Sep 2008 at 8:44pm
chassis does make a difference, in both cooling and working in the box.
power supply you only want what you need, and a bit more if you gonna upgrade. too much power is a waste of money
second dvd drive is pointless unless you have particular use/need for it right now. otherwise its not needed you can always put in your old one as a second
Edited by DST4ME - 13 Sep 2008 at 8:45pm
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 13 Sep 2008 at 9:26pm
Chasis, like everything else, should be balanced against your budget and the things you want from your system. Storing video eats up drive space quickly. You did mention a desire to do some video editing, so I included a terabyte of drive space in the configuration I suggested. Two hard drives is cheaper than a 1 TB drive and easier to maintenance.
If you can afford to drop in a 750W power supply into my listed configuration, you would be able to run an SLI 9800GTX+ configuration at a future date. This is a very powerful setup, but a single 9800GTX+ will be quite able as well. It comes down to budget and what you want from your system.
In answer to your original question, yes, if you select the overclocking option, your CPU comes to you overclocked and stability tested.
  Quote tang526 Quote  Post ReplyReply bullet Posted: 13 Sep 2008 at 11:11pm
thank you both for helping me..
i can always buy a new power supply in the future for upgrades,
i totally forgot that i need to buy a monitor, i'll look on newegg like you suggested DST4ME
in terms of the chassis, the Antec 900 only has 2 usb ports... i could get one of those multi usb things, but i never bought one before... do you know if they work well?
haha o yeah, since i'm going to end up paying lil more than planned, whats the deal with the internal lights? will i have to replace them often?... i mean its only 10 more "chucks"
and i heard t theres also no tax? yes?
THANKS AGAIN... i'm almost ready to click buy
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Sep 2008 at 11:23pm
internal lights shoud be fine they are just led-s
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 14 Sep 2008 at 12:49am
There will be tax if you're in CA. Not sure if any other state has a goofy law adding tax. I thought NY was looking to tax from anywhere . Tongue
Regarding your monitor, if you can get a widescreen, it is so much nicer with movies that are widescreen. You get more of the movie that way. Choices are hard to make in the budget category. If you can see them in person, that would help in deciding. Considering your use, I would stick with a sound card like the razer baraccuda. Plug in some nice Grados or Sennheisers and you'll be set for good tunes and flicks. Big%20smile
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 14 Sep 2008 at 1:24am
You will still have the rear USB ports to use. If you wanted on additional front port, get the media reader, it has a USB port in addition to ports for media cards. The internal lights are not LED's but rather cold cathode tubes. They are rated for something insane like 30,000 hours.
RHOreo View Drop Down
  Quote RHOreo Quote  Post ReplyReply bullet Posted: 14 Sep 2008 at 1:44am
Here is my setup and I work part time as an entertainment photographer so I will use photoshop quite a bit. I dont need the fancy lights, SLI or overclocking, just a basic system that will do the job and has some flexibility down the road. With this I have two USBs in front and six in back, including the card reader for my CF and SD cards. If you have a FRY's near you, you can pick up a good monitor for about $200.
Order Contents:
- Digital Storm Desktop 71105 Quantity: 1 $1,735.00
System Memory: 2GB DDR2 OCZ at 800MHz
Hard Drive 1: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Optical Drive 1: - No Thanks
Video Card(s): NVIDIA GeForce 9800GTX+ 512MB
CPU Boost: - No Thanks, Please do not overclock my processor
Office: Nero Express CD Writing Suite
Pre-Install Game: - No Thanks
Sub-Total: $1,735.00
Tax: $151.81 (for CA)
S&H: Ground $0.00
Grand Total: $1,886.81
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Sep 2008 at 2:49am
my mistake on teh lights sorry abbout that.
I like to also say that widescreen is the way to go as widdlecat has suggested
  Quote tang526 Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 12:26am
http://www.digitalstormonline.com/comploadsaved.asp?id=183051
heres the one i might go with
http://www.digitalstormonline.com/comploadsaved.asp?id=183229
now i reconfig that.. because my mom called my uncle (who is paying for some of it for a grad gift) and he suggested not to overclock the processor because it has more chances for crashing and to overclock the videocard, so i did that
i also got rid of the the lights EVEN THO they look so badass, they might be overkill
and i change chassis to the airmaster
and does anyone else think 1 TB is overkill cuz i sure dont.. i dont like to compress my music to mp3 cuz it hurts my ears.. i need quality music, so i use apple lossless on my itunes which takes quite a bit of memory
Edited by tang526 - 15 Sep 2008 at 12:28am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 12:53am
I'm sorry but your uncle is wrong, and not very informed about over clocking, if you don't know what you are doing then yes your pc will crash but when done right its no different then no OC as far as perfomance, with the exception ofcourse that oc runs faster.
there is no point in ocing the gpu, he told you backwards
second build is better, I wish you would atleast get teh liquid cooling.
oh well, its still a good build
  Quote tang526 Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 12:59am
he and his friend are re doing the config once again....
he's trying to knock it down a $100
and i'm convinced that i dont need the quad, some i'm getting the dual
Edited by tang526 - 15 Sep 2008 at 1:14am
  Quote tang526 Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 2:05am
we got the price down to $1887   put the extra money into a better and bigger moniter.
quad chip is only necessary of a few games that are currently available hey suggest lower to intel core 2 due E8500 3.16  -$73
get rid of the light-scribe…need to use special disc to burn i…just use marker  -$10
system memory drop to 2gb corsair  -$82   he’s it should for photoshop
no lighting  -$10
no overlocking $-45
air cooled stage 1 cooling -$129   don’t need it especially when u don’t overclock
he’s says to upgrade to
sound card  creative sound blaster X-fi FPS  + $90   for sound quality and extra RCA plugs for the front of the pc
use XP-Pro instead of vista     +$11
anyone else agree?
Edited by tang526 - 15 Sep 2008 at 2:11am
  Quote tang526 Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 2:12am
please post soon... i mean i DO want others opinion, you probably know more than i do
and i DO want it soon because i want that savings offers that ends in a couple of days
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 3:06am
I think its a mistake not to go with quad-core, most games coming out in the next year and future will be utilizing quad-cores,
I think its a mistake to go with only 2GB of ram, again most games coming out will need more then that to run well.
I think its a mistake to go with stage one, its not for OC its to keep the PC cool.
mistake to go with a sound card if you don't really need it.
I think its a mistake to go with XP, some games will work with directx10 which XP can't do, vista will see all your ram XP won't.
I can't say I agree with any of those changes, with a possible exception of the sound card and dvd drive.
you don't need special disk to burn, only if you want to have the label scribed then you would need it, otherwise you can use it as a regular DVD, but if you don't like it, a regular one is fine too
Edited by DST4ME - 15 Sep 2008 at 3:07am
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 12:56pm
$1995
Even the most mild of overclocks will have a Q9300 operating faster than an E8500. The case selected, in combination with the stage 2 cooling will ensure the system operates cool and quiet. I did drop you down to a 160GB HDD for your OS and games, and left a single 500GB for music and data files.
Edited by Tyler Lowe - 15 Sep 2008 at 1:01pm
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 1:22pm
First, I have to step out and say NO to the Creative xfi for audio. The Razer Baraccuda is better audio-wise and will not have the various potential problems that creative has with a combo of nVidia chipset and Vista. As an experienced audio person (designer, builder, consultant, reviewer) I understand the dreaded sound of mp3s, but go further to say that "lossless" sony is still a compression scheme with its own share of digital anomalies. Unless you have literally tens of thousands of songs on your iTunes, I can't imagine you filling a 500GB HDD. TB drives are expensive and two 500GB drives are safer storage. If one goes, you only lose half your music.
Second, your last two configurations looks like solid choices, but then when your uncle and his friend chose to bring the price down, he also gave you a rather slimmed down budget system. Not that that is a bad thing, it's just that everything seems to have changed. If that is so, then let us work with a new budget. Tyler has come up with a good system that would work rather well for your needs and still take advantage of what is available in the price range.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 1:53pm
I think TL has taken it as bare-bone as you can go, you can always drop the second HDD and get one later.
  Quote tang526 Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 3:22pm
where would i go abouts to add another hdd
Edited by tang526 - 15 Sep 2008 at 3:23pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 3:27pm
If you mean say a few month, then you just look for one say from newegg or a PC store near you, and then bring it home and install it, you can come here and we will help you install it, if you need that help, cause its super easy.
  Quote tang526 Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 3:34pm
wow, thanks alot... i'm really liking this configuration.. its not two different to my previously choices and its only 100 more than my uncles revised version
althought, i'm convinced that i really dont need the light, so i might take it off...
yes i think i am going with TL 's config...
is the RZ really bettre than the creative?
  Quote tang526 Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 3:55pm
oh i guess i better order it soon too.... to take advantage of that $100 off, right?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 4:31pm
sure but I think that has been around a while, you can take the lightoff if you like they are no biggie
  Quote tang526 Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:54pm
what has been around for a while
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:58pm
the discount.. oh hi alex
  Quote tang526 Quote  Post ReplyReply bullet Posted: 16 Sep 2008 at 9:02pm
well s*** i should of took off the light and save a lil money..
randy called me and told me they didnt have the 9800gtx in stock and they had the 9800gtx+ .... so that raised me to 2034... so much for saving the extra couple $100 Big%20smile
  Quote tang526 Quote  Post ReplyReply bullet Posted: 16 Sep 2008 at 9:03pm
oh anyone know a good place to buy a HD monitor.. i mean i might as well buy a high monitor since i'll be using that for a long long time
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Sep 2008 at 9:23pm
rai-zero View Drop Down
  Quote rai-zero Quote  Post ReplyReply bullet Posted: 17 Sep 2008 at 11:40am
don't want to step on any toes about going around buying outside parts but you can find some good deals look around. I found and ordered this monitor at circuit city.
This is the same 24" offered by DS for $525 I got for $311 (after sales tax and after $70 mail in rebate). I already have the monitor but have not tested it since I am awaiting my PC.
http://www.circuitcity.com/ssm/Samsung-245BW-24-Widescreen-Monitor-245BW/sem/rpsm/oid/185618/catOid/-12965/rpem/ccd/productDetail.do
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Sep 2008 at 3:28pm
newegg should have better prices then CC most times, good find tho.
  Quote tang526 Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 2:58am
well newegg looks good.. but every prroduct seems to have some bad reviews... which makes me cringe into buying one
but someone look at the BenQ monitor for $399, i'm thinkg about that one... someone should look at it because i dont know if i would be making a bad decision
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Sep 2008 at 3:44am
everything is gonna have cons and pros.
what you need to look at is
A: are the cons something that concerns me
B: how many of them are there comparing to the positive reviews.
This page was generated in 0.1149902 seconds.
