intel core 2 duo e8500 OC I NEED HELP!
Post Date: 2010-11-28
duffs View Drop Down
  Quote duffs Quote  Post ReplyReply bullet Topic: intel core 2 duo e8500 OC I NEED HELP!
    Posted: 28 Nov 2010 at 9:02pm
I need help over clocking my intel core 2 duo e8500 if someone could help me I could pay you something.
Even if you’re on the right track, you’ll get run over if you just sit there.
Landaulet View Drop Down
  Quote Landaulet Quote  Post ReplyReply bullet Posted: 30 Nov 2010 at 2:08pm
Honestly you would be better off upgrading cpus if possible.
rrplay View Drop Down
  Quote rrplay Quote  Post ReplyReply bullet Posted: 23 Dec 2010 at 11:52am
you would need to evaluate your case &  cpu cooling overall psu quality etc
gather the info regarding your mainboard ,be familiar with editing your bios
 read some guides that are posted here and elsewhere to optimize your current setup at stock speeds & check for stability by using and monitoring some apps that are common a mutually accepted to maximize your OC attempts
Overall it takes a bit of your time 1st to post the specs of what you have and to share with others.and test would take a commitment of your time as well
The advice previously give to upgrade your cpu and memory will give you better stable performance in a fraction of the time.
you could even post your current hardware info in this forum about what would be the best cost effective upgrade and get some timings that would make a real difference overall
