Intel G3 RAID 0 Help
Post Date: 2011-05-13
Dsnewb210 View Drop Down
  Quote Dsnewb210 Quote  Post ReplyReply bullet Topic: Intel G3 RAID 0 Help
    Posted: 13 May 2011 at 1:49am
Hey guys, finally pulled the trigger on 2 intel 160's and decided to do a raid 0 setup. Only problem is.... I have no clue where to start. Ive only installed traditional hard drives and have never raided them. Anyone know a guide or could possibly walk me through the process? I want to get the best performance out of my drives, I know there are all sorts of striping sizes. My mobo is an asus rampage II extreme, running bios version 1504 if that matters at all. Also whats the best way to wipe a drive? I plan on using my 300gig velociraptor for music/junk files. Thanks in advance, to all that reply.
Edited by Dsnewb210 - 13 May 2011 at 1:51am
950SI
965/4.0 Frostbite LC
6GB Dominator 1600mhz
Rampage II Extreme
Intel 160 320 Raid 0
GTX 285 SLI
Dell 2408wfp/2407wfp
Logitech G19, Razer Mamba
Wireless Astro A40's
Bose Companion 5 Speakers
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 13 May 2011 at 11:39am
Are there ide/achi firmware updates I have to do as well on the board itself?
950SI
Rampage II Extreme
GTX 285 SLI
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 14 May 2011 at 10:04pm
Where is dragoonseal!! Hahaha
Edited by Dsnewb210 - 14 May 2011 at 10:05pm
950SI
Rampage II Extreme
GTX 285 SLI
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 16 May 2011 at 5:08am
This is simple Google search worthy stuff.
Assuming you are doing a fresh Windows install: If it isn't already, set the BIOS to RAID mode, then when you start the PC keep pressing Ctrl+i to bring up the Intel RAID configuration utility. Pick the two drives, RAID 0, the size of the array (it will default to full size, should be about 297GB), and stripe size (default is 128KB, which is usually the best all around size), name it what you want, then save and exit. Finally, restart with the Windows 7 install CD/DVD and install onto said new array.
Lilim
Intel Core i7 920 @4.2GHz
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 16 May 2011 at 12:44pm
Sounds easy enough! Hopefully my ssds make it today.
Any suggestions on the best way to wipeout the data on my main hd? I'd like to use it for media stuff.
Edited by Dsnewb210 - 16 May 2011 at 12:46pm
950SI
Rampage II Extreme
GTX 285 SLI
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 16 May 2011 at 10:44pm
Yes, very easy, possibly even easier than it sounds as the Intel RAID utility pretty much walks you through it.
Wipe a normal conventional HDD? After you've installed Windows and boot up, right click My Computer and click Manage, then under the left menu click Disk Management. Find the HDD in the list, right click it, click Format, and click okay.
Lilim
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 16 May 2011 at 11:11pm
Wipe out...or repurpose? If it's wipeout and delete all traces of data on it, I recommend DBAN.Otherwise, if you're just repurposing, yep you just format it.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 17 May 2011 at 12:40am
I'm just gonna format it, plan on using it for my media crap. Thanks guys for all your help.
950SI
Rampage II Extreme
GTX 285 SLI
