Is 600w power supply sufficient enough for 2070s
Post Date: 2020-08-30
Ty82 View Drop Down
  Quote Ty82 Quote  Post ReplyReply bullet Topic: Is 600w power supply sufficient enough for 2070s
    Posted: 30 Aug 2020 at 5:45pm
I'm getting my Lynx 4 tomorrow but was looking up power supplies for 2070super and I read that 2070super should use 650 minimum.
Will I be ok with the 600w?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 31 Aug 2020 at 3:40am
DS certifies their 600W up to an RTX 2070. They have sold hundreds of these units since the 2070 became part of the build without an issue.
Bob100 View Drop Down
  Quote Bob100 Quote  Post ReplyReply bullet Posted: 01 Sep 2020 at 7:03pm
From: https://www.guru3d.com/articles-pages/geforce-rtx-2060-and-2070-super-review,5.html
Here is our power supply recommendation:
GeForce RTX 2060 Super - On your average system we recommend a 500 Watt power supply unit.
GeForce RTX 2070 Super - On your average system we recommend a 550 Watt power supply unit.
If you are going to overclock your GPU or processor, then we do recommend you purchase something with some more stamina. Also, at half the PSU load (50% usage) your PSU is the most energy efficient.
Edited by Bob100 - 01 Sep 2020 at 7:04pm
Ariktu View Drop Down
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 02 Sep 2020 at 1:05am
My system is running fine on a 600 watt and an RTX 2070 suoer.
I do plan on moving to a bigger power supply at some point since I intend to down the line move to a 3070.
This page was generated in 6.005859E-02 seconds.
