Is a Radeon 5850 Overkill for My Application?
Post Date: 2010-07-15
cohenfive View Drop Down
  Quote cohenfive Quote  Post ReplyReply bullet Topic: Is a Radeon 5850 Overkill for My Application?
    Posted: 15 Jul 2010 at 12:33pm
i'm putting together a pc build for to replace our 4 year old dell which just isn't up to the task any more. primary use (other than normal home/office and internet use) is working with large raw image files, maybe fooling around a big with video but on an amateur basis. gaming will be on the light side. i've spent money on graphics cards in the past and am wondering how powerful a card i need for this build. my current thinking is a radeon 5850, but if that is a dumb idea in either direction i'd like to hear about it. most of the extra money i'm spending on my build is on fast and large storage (80gb ssd, 2 tb hdd). the rest is pretty standard--core i7 930, 6gb ram, haf 922 case, etc.
i'd also appreciate advice on whether i would notice performance benefits from overclocking the cpu a bit. the reason i hesitate is that if i overclock i guess i also need to upgrade cooling which adds to the cost..and i'm already up against what i want to spend on the pc so am trying to go the other way if possible.
thanks!!
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 16 Jul 2010 at 6:55am
depends on your monitor size
but uh, it would be a good investment, for light gaming.
  Quote cohenfive Quote  Post ReplyReply bullet Posted: 16 Jul 2010 at 9:22am
i use a dell 2209wa e-ips monitor. some chance i'll go a bit bigger at some point but i really like this monitor's performance. when i switched to this monitor about a year ago i really noticed a big difference in what i was seeing....
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 16 Jul 2010 at 9:27am
try a GTX 460, designed specifically for the mainstream market, and it's only $199...or a ATI 5830.
in addition, never overclock a dell. dell's are made from the cheapest grade parts available, namely lots and lots of Foxconn stuff, which is why they are so....well...cheap. if you try to overclock a CPU on a dell motherboard, then it'll try to do it, but will burn out and fry itself very very fast because it can't take even mediocre voltage adjustments.
Edited by ablahblah - 16 Jul 2010 at 9:29am
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
