Is there a way...
Post Date: 2009-06-25
Ramdurand View Drop Down
  Quote Ramdurand Quote  Post ReplyReply bullet Topic: Is there a way...
    Posted: 25 Jun 2009 at 2:20pm
To check how fast your memory is on Vista.  I tried looking everywhere for it on the control panel and on the computer icon.  All i could find is that it said you have 6 gigs.  I want to know how fast it is.  I ordered 1333 and when i turned it on today i saw something say DDR3 1066.  I am hoping its not that.  Any help would be great.
Thanks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 2:26pm
Ramdurand to give you a better OC they may need to lower ram ratio to achieve higher OC, ram speed makes very little difference which is why I recommended the 1333MHz rather then 1600Mhz to you originally.
having said that, if this was during boot-up, then disregard its false.
last if you want to see what ram you got run CPU-z and look under "spd" tab and tell me what is the "max bandwidth" listed there.
Edited by DST4ME - 25 Jun 2009 at 2:27pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 2:38pm
On Evga motherboards, during boot up, instead of showing actual memory speed, it will show the default b-Clock x the Ram multi. It is very misleading. lol
Like DST said, get cpuz and look at the memory tab, and take what it says and multiply x 2.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 2:46pm
lol or use the spd tab and devide "max bandwidth" by 8
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 2:54pm
That will not show the actual speed though.
Edited by justin.kerr - 25 Jun 2009 at 2:54pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 3:01pm
he wants to know if got the 1333MHz ram he ordered, that will show him what speed ram he has.
for what speeds the ram are running at, your method is correct
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 3:09pm
Let me show you something. lol
What speed of ram is this?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 3:46pm
do you mean what is the ram speed running at or what is the stock speed of ram at the time of purchase?
stock speed at the time of purchase looks to be 2000MHz
Edited by DST4ME - 25 Jun 2009 at 3:48pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 4:09pm
I was going by your         "if you want to see what ram you got run CPU-z and look under "spd" tab and tell me what is the "max bandwidth" listed there."  Idea.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 4:18pm
lol but yours is not stock, you oced/changed timing of your ram right?
Edited by DST4ME - 25 Jun 2009 at 4:19pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 4:25pm
DSO might have changed the OP also. lol Just trying to point out that that way can be inaccurate because of what cpuz reports. Some ram reports off there.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Jun 2009 at 5:15pm
you are correct, however if you told me you bought 2000MHz ram and then reported your max bandwidth at 10700, it would be obvious that your am is not reported correctly and we need a screen shot of spd and memory tab, no arguements there.
Edited by DST4ME - 25 Jun 2009 at 5:15pm
This page was generated in 7.666016E-02 seconds.
