iTunes doesn't load?
Post Date: 2013-05-11
davep View Drop Down
  Quote davep Quote  Post ReplyReply bullet Topic: iTunes doesn't load?
    Posted: 11 May 2013 at 8:55pm
So I installed a new hard drive, reinstalled windows and almost all my software programs. And of course waited for windows to install all the updates over several days to catch up.
I finally went to download iTunes. Everything appeared to download, but when I clocks the icon, nothing happens.
Any thoughts
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 May 2013 at 3:27am
Go to Add/Remove programs and uninstall Quicktime.   Thats seems to do it for alot of others.    Repair Quicktime might also work.       For iTunes there might be a couple of different Winx64 files. Try both.
Good luck.
  Quote davep Quote  Post ReplyReply bullet Posted: 14 May 2013 at 7:22pm
Problem solved.
When I brought over my files and file folder from my backup external hard drive, I brought over my iTunes files and folder. Once I delete the files and file folder, iTunes loaded and created it own file folder in "music". Apparently it locked up when it found a iTunes folder already in place.
Also since music is stored in the cloud I don't know if you can stored music on your PC in the same way
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 May 2013 at 3:36am
Good to hear.
This page was generated in 7.568359E-02 seconds.
