Lapping CPU/Cooler
Post Date: 2010-02-06
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Topic: Lapping CPU/Cooler
    Posted: 06 Feb 2010 at 2:38pm
I have no intention on doing this really but am very curious if any high end overclockers on this forum like Justin.Kerr or anyone else does this.  I have been reading a lot of mixed feelings on this subject as to if this helps or not.  I read on Noctua's page that they actually leave a slightly machined surface because they feel this works better with the modern thermal pastes.
Any strong opinions on this issue?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 06 Feb 2010 at 2:57pm
I have lapped 10-12 setups, and know of a lot of people that have done it to.
Yes if the CPU cooler has a solid copper plate, then lapping will help. How much? well that varies greatly, every cooler will be different and so will every chip, so some will mate up better than others, the ones that do not mate up very well will see the largest gain in lapping. 10C lower temps can happen, but usually 2C-4C is what to expect for most higher clocked setups.
Mirrored polish on both, completely flat on both is best, but it takes some elbow grease. lol
This is a pretty common practice, and no big deal, like direct die cooling now thats for the pros. lol
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 06 Feb 2010 at 3:16pm
Thanks for the reply.  I have watched a few video's of people doing this and I was wondering if it actually paid off or not.  Some people seem to swear by it and other think it's really dumb to do.  You are confirming what I thought; that it'll give mild results.
now curious and researching direct die cooling lol..
Edited by AndydViking - 06 Feb 2010 at 3:17pm
MyNameisBrian View Drop Down
  Quote MyNameisBrian Quote  Post ReplyReply bullet Posted: 06 Feb 2010 at 4:09pm
What do you think of peltier cooling?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 06 Feb 2010 at 11:41pm
me? Peltier makes zero sense at all.. just me
sirsiddius View Drop Down
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 07 Feb 2010 at 5:24pm
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Posted: 07 Feb 2010 at 5:33pm
Peltier is interesting. I like how it works but it doesn't have a middle ground, it's either dangerously cold (condensation) or not strong enough at all. If a computer ran the same speed, all the time, it makes sense. But most computers don't. Personally I'd rather see peltier used on cooling solar cells. At least that's just what I'd do with it anyway.
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 07 Feb 2010 at 8:29pm
http://www.tomshardware.com/news/thermoelectric-cooling-cpu-tec-peltier,7037.html
I think the CM v10 usues Peltier cooling.
I always wondered if someone got one of those portable AC's (the ones you don't need to put in your window). And then got ducting to all your fan intakes if it were to make any real difference.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 08 Feb 2010 at 8:55am
for 24/7 use water or air makes sense, for benching phase change, or LN2/Helium/DICE
This page was generated in 7.501221E-02 seconds.
