Laptop Build Help
Post Date: 2013-02-22
bighunt View Drop Down
  Quote bighunt Quote  Post ReplyReply bullet Topic: Laptop Build Help
    Posted: 22 Feb 2013 at 12:35pm
Hey guys and gals!
First time poster, long time lurker here as DS. I love the site and the computers you offer. I've been shopping for a new laptop for a while now. Nothing too wrong with my current Sony, but won't be able to play the new Sim City.
Disclaimer: I'm a Console gamer, but I am looking for a good gaming laptop that doesn't necessarily have to be top of the line.
Budget: ~$2k.
Expectations: I won't be playing many games, But when I do venture into a game (specifically the newest Sim City), I want to run it without any hiccups.
Usage: Web surfing, watching movies, listening to music, playing Sim City.
Special Needs: 15" only. And a Blu-Ray Player. I just want a new laptop that will last me 4+ years with good specs.
Here are 2 Configs. I would love feedback and suggestions. Thanks guys!!
Config #1
Ticket Number: 791115
Total Price with Instant Savings: $2,024.00
Chassis Model: Digital Storm x15E Laptop (Model: 9150)
Display: 15.6 Inch (16:9) (Resolution: 1920 x 1080) (Glossy Surface) LED-Backlit Display
Processor: Intel Core i7 3740QM (2.7 GHz Turbo Mode to 3.7Ghz) (Quad Core) (6MB Cache)
Thermal Compound: Stock CPU and GPU Thermal Compound
Memory: 16GB DDR3 1600MHz (4x4GB Sticks) <b></b>
Primary Hard Drive: Intel 240GB SSD (520 Series) (SATA 6Gb/s)
Secondary Hard Drive: - Not Available
Optical Drive: Blu-Ray Player (Blu-Ray 6x) & DVD/CD Writer
Wireless Card: Intel Ultimate-N 6300 Wireless LAN Module
Video Card(s): NVIDIA GeForce GTX 670MX 3GB with NVIDIA Optimus
Config #2
Ticket Number: 791125
Total Price with Instant Savings: $1,823.00
Processor: Intel Core i7 3630QM (2.4 GHz Turbo Mode to 3.4Ghz) (Quad Core) (6MB Cache)
Memory: 12GB DDR3 1600MHz (3x4GB Sticks) <b></b>
Thoughts? Suggestions? Thanks!
Optimus.Prime View Drop Down
  Quote Optimus.Prime Quote  Post ReplyReply bullet Posted: 22 Feb 2013 at 12:54pm
The only one suggestion I have for build 1 is drop the Memory down to 8GB. They currently have a deal where it automatically gets upgraded to 16GB.
DomTheBomb View Drop Down
  Quote DomTheBomb Quote  Post ReplyReply bullet Posted: 22 Feb 2013 at 7:06pm
Neither of those will have any trouble running Sim City, or any game in general. However, if you want a little more eye candy in your games, you should consider spending a little more for the 7970M, which is currently tied with the 680M as the best mobile graphics card out there.
Here's an example of a build with the 7970M:
Price: $1,990
Memory: 8GB DDR3 1600MHz (2x4GB Sticks)
Primary Hard Drive: Intel 120GB SSD (520 Series) (SATA 6Gb/s)
Optical Drive: DVD/CD 8x Multi-Drive (Writes and Reads DVDs, CDs)
Video Card(s): AMD Radeon HD 7970M 2GB
I would definitely stay with the 3740QM, it's a great processor that will be handling anything you throw at it for years.
8GB memory is more than enough, and you'll get even more with the free promotion.
Had to drop the SSD size down a little, but you can always replace that or buy more external storage. If you're not playing many games even 120GB should be enough space.
I got rid of the blu-ray drive, mainly because a slim type blu-ray drive is fairly expensive, and most people don't end up using them enough for it to be worth it (like myself). The money for a gaming laptop should really be put in to the GPU and CPU. If you do watch enough blu-ray movies to really need one, then you can put it in and the total cost comes to around $2040
The 7970M is a great card, approximately 30-40% better than the 670MX. The 7970 will play most games at 60fps on high-ultra settings, which the 670mx won't. If you want your GPU to last 3-4 years, the 7970m is definitely the card to go for.
Any build you go with will still play games like Sim City great, and you'll get a great laptop from a great company.
If you have any questions on that build or just on a DS laptop in general I'd be happy to answer them.
Edited by DomTheBomb - 22 Feb 2013 at 7:07pm
DS x17, 1 Year 5 Months
i7 3720QM (2.6GHz/3.6GHz)
16GB 1600MHz DDR3
Nvidia GTX 680M 4GB
240GB Intel 520 SSD
Windows 8.1 Pro
  Quote bighunt Quote  Post ReplyReply bullet Posted: 24 Feb 2013 at 8:35am
Thanks for the suggestions!
 2 Questions: Is there an HDMI output on the laptops? What speed is the USB ports? 2.0 or 3.0?
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 24 Feb 2013 at 8:39am
From looking at the laptop you picked. It has (2) 3.0 usb ports and (1) 2.0 usb port, 1 hdmi output jack. If you click on view gallery it shows all the ports and stuff on it.
Edited by ArkansasWoman777 - 24 Feb 2013 at 8:57am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Feb 2013 at 10:00am
DTB has some great info for your there, you can upgrade ssd and things like that later, if you need help just call DS or come here and we will walk you thru.
And as much as we love the 670 gtx its mobile version is not that great unfortunately, so its a 680m or the 7970m, and as DTB mentioned 7970m is the best bang for the buck in your build.
  Quote DomTheBomb Quote  Post ReplyReply bullet Posted: 24 Feb 2013 at 10:38am
The naming scheme for the mobile GPUs doesn't actually correspond to that of the desktop, even though it really should. It's very misleading, but here are what the mobile cards are in terms of their desktop counterparts:
The 670MX is an underclocked desktop 660.
The 675MX is the same but with a wider memory bandwidth.
The 680M is an underclocked desktop 670.
The AMD 7970M is an underclocked desktop 7870.
This does show though how much of a performance increase the 680M or 7970M will have over the 670MX.
16GB 1600MHz DDR3
Nvidia GTX 680M 4GB
240GB Intel 520 SSD
Windows 8.1 Pro
  Quote bighunt Quote  Post ReplyReply bullet Posted: 25 Feb 2013 at 12:57pm
One quick follow-up question:
I will stick with the 8gb RAM b/c I believe the "Free Memory Upgrade" is still in effect. When I order my laptop, do I need to remind them to double my RAM to 16gb?
  Quote DomTheBomb Quote  Post ReplyReply bullet Posted: 25 Feb 2013 at 6:40pm
Can't hurt to mention it, but they should take care of it.
16GB 1600MHz DDR3
Nvidia GTX 680M 4GB
240GB Intel 520 SSD
Windows 8.1 Pro
