Laptop Configuration Help
Post Date: 2010-12-18
cyberzs40 View Drop Down
  Quote cyberzs40 Quote  Post ReplyReply bullet Topic: Laptop Configuration Help
    Posted: 18 Dec 2010 at 10:42pm
Looking to buy a laptop for university. Mostly for work, but some gaming would be nice. Preferably looking for portability. As for screen size I've decided on the 15.6".
Budget: $1500
Mostly programming and web design. May include some photoshop and flash.
Not a hardcore gamer, but do wish to play some of the current and upcoming games in high or ultrahigh settings.
Note: not a fan of FPS games, mostly games like assassins creed.
Any suggestions? Thanks.
Edited by cyberzs40 - 19 Dec 2010 at 6:49pm
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 18 Dec 2010 at 11:33pm
Are you looking for something that leans more towards portability, or something that is primarily going to be sitting on a desk, plugged in, and not moving a whole lot?
Any preferences on screen size?
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 1:09am
ok, sorry for lack of information, I've edited the post with a bit more info. Hope that'll get some more replies and suggestions. Will be glad to provide more details if needed.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 1:25am
not much to get on laptops really, for your use you want a good cpu, and good enough ram for editing, if you are not doing heavy duty then 6GB should be more then enough.
But by default laptops here come with one year warranty so make sure you ask DS for longer warranty, its $99 for each extra year I believe.
Edited by DST4ME - 19 Dec 2010 at 1:26am
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 1:41am
about the processor, what processor would you recommend will be sufficient for what I'm doing, and still be able to play some games.
Edited by cyberzs40 - 19 Dec 2010 at 1:49am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 2:06am
todays 4 cores should do fine.
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 2:17am
I'm at checkout and I notice the subtotal is the same price as my laptop config. Is the tax included in the subtotal?
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 2:19am
There's no tax unless you live in California, as DS has no brick-and-mortar stores outside of that state. (Someone please correct me if I am wrong)
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 4:23am
Correct, California only.
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 6:47pm
okay, I'm currently using the DS xm15 base config. DST4ME suggested a quadcore, but on the config I'm only able to get an i7 dualcore. Would that be sufficient for what i"m doing and still be able to play some games?
Also I noticed the 500gb solid state hybrid by seagate. What's the difference between that and the 500gb sata hard drive?
ticket number: 470584
Total Price with Instant Savings: $1,266.00
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=470584
Chassis: Digital Storm xm15 5135 (Weight: 5.73 LBS)
Display: 15.6 inch Full HD LED Display with Enhanced Super Glossy Surface (Resolution: 1920 x 1080)
Processor: Intel Core i7-640M 2.8GHz (4MB Cache) (Dual Core)
System Memory: 6GB DDR3 at 1066MHz (High-Performance)
Inputs: Gigabit Ethernet LAN / Card Reader / eSATA
Main Storage: 500GB (7200 RPM) (16MB Cache) (SATA Laptop Hard Drive)
Extra Storage: - No Thanks
Raid Options: - No Thanks
Optical Drive: DVD/CD 8x Multi-Drive (Writes and Reads DVDs, CDs)
Wireless Access: 802.11 B/G/N Wireless LAN Module
Features: Integrated Video Camera / Bluetooth
Outputs: HDMI 1080P / DVI Port / SPDIF Audio / Headphone / Microphone
Video Card(s): NVIDIA GeForce GT 425M 1GB (Features Optimus Technology for Increased Battery Life)
External TV Tuner: - No Thanks
Protection: - No Thanks
Office Suite: - No Thanks
Carry Bag: - No Thanks
External Cooling: - No Thanks
External Keyboard: - No Thanks
External Mouse: - No Thanks
External Speakers: - No Thanks
Full Warranty: 3 Year Platinum Care Labor & 1 Year Parts Warranty
Edited by cyberzs40 - 19 Dec 2010 at 6:48pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 7:53pm
I appologize, I forgot that i7 quad has not comeout yet.
if its in the budget ssd would be good to have in a laptop specially. 80GB intel is the one, if you think you can get away with 40GB go ahead but be sure that is enough, or you gonna end up getting this 40GB then later you gonna pay for a bigger ssd.
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 8:05pm
so, you mean to swap out the 500gb sata hard drive for the 80gb intel ssd?
Also, i noticed there's the 1x80gb intel ssd and the 2x40gb intel ssd. But the latter is $10 more expensive. Why is that?
Oh, and I appreciate the advice so far. Thanx.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 10:12pm
you want the 80GB ssd, that is one drive with 80GB of space the 2 x 40GB is exactly that, 2 40GB ssd in raid.
so yes if you have teh budget, get the ssd instead of the 500GB.
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 11:16pm
yes, I have the budget. so which one should I get? the 1x80gb or 2x40gb. Does one have the advantage over the other?
Also the size kind of bothers me. I'll mostly be doing coding work and web design which may include some photoshop and flash. And the occasional game or two. Would that be sufficient space?
sorry for all the questions. this is my first custom laptop.
  Quote venom Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 11:22pm
For a laptop I would recommend the 80gb.  The 2x40s would probably be a little faster, though I generally recommend to not get RAID0 due to a drive failure or for some reason the RAID array glitching (this is a software raid versus a true hardware raid), all of your data is lost.
One other recommendation would be to stay away from that Optimus crap.  I had nothing but issues trying to get the games to actually use the NVIDIA GPU versus the on-board Intel one (the battery saving one).
Edited by venom - 19 Dec 2010 at 11:25pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 11:28pm
I'm with venom, 1 x 80GB
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 11:52pm
Okay then, how about I switch to the Nvidia Geforce GTX 460M? Would this be recommended over the Optimus one?
  Quote venom Quote  Post ReplyReply bullet Posted: 20 Dec 2010 at 12:53am
I would recommend it if you want to avoid issues.  It may decrease battery life more than the Intel would, but I'd take less battery over more headaches any day.
I think that all of those laptops have that Optimus feature regardless of the video card, though I could be wrong.   Nevermind it is just the first model it seems.
Edited by venom - 20 Dec 2010 at 12:58am
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 20 Dec 2010 at 1:12am
Just trying to finalize my configuration. Is my configuration all right for what I'm trying to accomplish or is it overkill or perhaps I'm underpowered? Mostly programming, web design, photoshop and flash and the occasional game or two.
Also feel free to make and suggestions and/or changes to my configuration as you see fit.
My preferred budget would be $1500 but I do not mind going over as seen below. However, I would like to keep it under $2000. Thank you in advance for your time.
Ticket Number: 470674
Total Price with Instant Savings: $1,891.00
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=470674
Chassis: Digital Storm x15 8690T-8 (Weight: 7.38 LBS)
Display: 15.6 inch HD+ LED Display with Enhanced Super Glossy Surface (Resolution: 1920 x 1080)
Processor: Intel Core i7-720QM 1.6GHz (6MB Cache) (Quad Core)
Main Storage: 1x (80GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance)
Wireless Access: 802.11 A/B/G/N Wireless LAN Module
Video Card(s): NVIDIA GeForce GTX 460M 1.5GB
Carry Bag: Standard Carrying Bag
  Quote venom Quote  Post ReplyReply bullet Posted: 20 Dec 2010 at 3:50am
Looks good to me, what do you think DST4ME?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Dec 2010 at 4:18am
Looks good to me, or maybe we should tell him to put sli 570 in there
  Quote venom Quote  Post ReplyReply bullet Posted: 20 Dec 2010 at 5:06am
LOL! Yeah!
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 20 Dec 2010 at 11:50pm
Alright, one last question before ordering.
The i7 1.6GHz clock speed bothers me abit.
Assassin's Creed requires a 2.2GHz Core 2 Duo.
As I understand it all 4 of the i7's cores added up would be 6.4GHz. However most games only use up 2.  That leaves the i7 at 3.2GHz. So if Assassin's Creed uses up 2 cores and the recommended specs is a 2.2GHz dualcore, totaling 4.4GHz. Then wouldn't that mean the i7 wouldn't be able to handle Assassin's Creed?
On a sidenote, how well would the i7 1.6GHz handle most games?
Thank you for your input.
Qwann View Drop Down
  Quote Qwann Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 1:30am
I believe that the Labtop CPU's have Turbo-Boost, which is that when you're idling it will downclock the cpu to save battery, but when gaming will ramp up to around 3GHz. The 1.6 GHz is just idle speed, don't worry about it. Also, you don't multiply # of cores x CPU speed to get the (for lack of a better term) overall speed. Each of your cores run a little different than the others, but all of them are approximately the same speed. Multiple cores are utilized for additional programs such as listening to music while gaming,or newer games/programs that can take advantage of more than 1 or 2 cores.
@DST & Venom- I recently purchased a rig through DSO with !ender's advice and I appreciated his input, and although he has a different line of thinking than you guys, I think that simply agreeing to disagree would show a lot more maturity and wisdom then continuing to make snide comments.
Edited by Qwann - 21 Dec 2010 at 1:46am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 2:27am
Something are not a matter of opinion, there is a right and wrong answer, and when the wrong answer wastes people's money then thats just wrong. I'm not gonna go over it again, but telling people to get sli when the game they play does not even use it and their res does not even need it, is not a matter of opinion, its just wrong, you won't find one dignified person disagree with that statement.
@cyberzs40, as pointed out, you don't add up the core's speed, it does not work like that.
Edited by DST4ME - 21 Dec 2010 at 3:36am
  Quote venom Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 3:55am
@Qwann agreed, however if you were recommended additional parts that were not required for what you wanted to do, wouldn't you be pissed off once you found out you wasted all that cash for no gain in performance?  I know I would be.
In regards to the core speed, I highly doubt you will have any issues even if the clock speed is lower.  The game is recommending a previous generation chip anyway.
Edited by venom - 21 Dec 2010 at 3:57am
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 7:05am
Haters gon' hate, don't waste your time qwann.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 7:07am
LOL ya haters, haters of wasting money, you dadgum right
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 12:33pm
I see, thanks for clearing up my doubts.
I have a bit more cash leftover so....
Just wondering, performance wise, would the i7 1.73GHz be worth the extra $41? Or should I bump up the ram to an 8GB(though I probably shouldn't bother as I don't need that much ram for work or play)
Edited by cyberzs40 - 21 Dec 2010 at 12:34pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 2:09pm
If you don't need the ram, then don't waste money on it, you get 2MB of extra cache on the 740qm and above, not sure if the difference is worth the performance.
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 2:49pm
I'm confused, last I checked the 740QM only had 6mb of cache which is equivalent to the 720QM. Only difference was that the 740QM had 1.73GHz while the 720QM had 1.6GHz. Where did you get the extra 2mb of cache for the 740QM?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 3:21pm
hold on let me go check, maybe its after 740 and I made a mistake.
I stand corrected it is after 740qm that the cache goes to 8MB.
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 4:39pm
Now that you know the cache is the same and the only difference is the clock speed. Do you think the i7 1.73GHz is worth the xtra $41? Or are you still not sure?
Just asking for your opinion.
PS. I may have a couple more questions later. thank you for your patience.
Edited by cyberzs40 - 21 Dec 2010 at 4:40pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 5:26pm
IMHO its not worth it.
ask as many questions as you like.
  Quote cyberzs40 Quote  Post ReplyReply bullet Posted: 21 Dec 2010 at 6:46pm
Hi, I notice that the ram has different speeds. What advantage would faster ram have over a slower one of the same GB and when would you use one or the other?
