Laptop cooling question(s)...
Post Date: 2012-05-11
Trumpeteer23 View Drop Down
  Quote Trumpeteer23 Quote  Post ReplyReply bullet Topic: Laptop cooling question(s)...
    Posted: 11 May 2012 at 2:56pm
Hello all,
I was wondering about the current 15" laptop model, and how well the air flows through it. Do you think I'll need a laptop cooling pad, or will the laptop, being on a open and clutter-free surface be enough? My room is typically on the cooler side, which is good for gaming because systems and computers tend to give off lots of heat. Idk, maybe I'm just paranoid about overheating issues. It wouldn't be too much of a problem to get a cooling pad, but it seems like these laptops have enough height and vents to keep it at a good enough temp. Any thoughts? What do you do to keep your laptop cool, if anything?
Edited by Trumpeteer23 - 11 May 2012 at 2:59pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 11 May 2012 at 6:12pm
The laptops are designed fairly well and don't really require a laptop cooler unless your room is very hot (80'F+) or if you have the laptop sitting on your lap which may be blocking some vents.
