Laying machine on it’s side?
Post Date: 2018-02-25
andr.del View Drop Down
  Quote andr.del Quote  Post ReplyReply bullet Topic: Laying machine on it’s side?
    Posted: 25 Feb 2018 at 10:41am
Greetings DS fam.
Qualifiers: mega noob when it comes to hardware. My order from DS arrived & it’s my first desktop unit (had laptops through college & first job is all Mac stuff). So apologies for the maybe super obvious clarification I’m about to seek. My specs are at the bottom in-case they’re relevant.
Question: I have a standing desk at my apartment (where I do all of my free time tech stuff). This is where I intend to use and house my new DS pc! The height of the bolt x (or more realistically, my excessive paranoia in general about everything) makes me feel somewhat nervous about standing the bolt upright on said desk. I go for a pretty sleek minimalist look at my apartment and I don’t want to add any unnecessary suspension wires or belts etc to ensure it won’t get knocked over by my extremely clumsy arms / friends. Can I lay the bolt on its side? Obviously I can lay it on its side — but will this have any adverse effects in the way of performance, dust & cooling management or other machine health & longevity factors?
Thanks in advance, all! Reading through the sheer responsiveness of the DS community definitely factored into my purchase.
Cheers.
Chassis Model: Digital Storm BOLT X
Side Window: Edge to Edge Premium Acrylic
Processor: Intel Core i7-8700 (6-Core) 3.20GHz (Not Overclockable)
Motherboard: MSI Z370I GAMING PRO CARBON AC (Wi-Fi) (Intel Z370 Chipset) (Mini-ITX) (Up to 1x PCI-E Device)
System Memory: 16GB DDR4 3000MHz Digital Storm Performance Series
Power Supply: 750W Lian-Li PE-750 (Platinum Rated) (Supports up to GTX TITAN Xp)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (500GB Samsung 960 EVO) (NVM Express)
Storage Set 2: - No Thanks
Graphics Card(s): 1x GeForce GTX 1070 Ti 8GB (VR Ready)
Extreme Cooling: H20: Stage 2: Corsair H115i - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance)
Chassis Fans: Standard Black 140mm Fans
Internal Lighting: Remote Controlled Internal + Front Panel LED Lighting
Airflow Control: - No Thanks
Recovery Tools: Windows 10 Installation CD Only (Clean Install with No Drivers)
Edited by andr.del - 25 Feb 2018 at 1:00pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Feb 2018 at 11:19am
Yes, you can lay it on it’s side. The Corsair H115i is a sealed unit and doesn’t care it’s orientation.   The other parts also don’t need to be right side up.   I would however put spaces or feet on all four corners to allow airflow for the bottom air chamber or if there’s a fan on the back.
Congrats on the new rig.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 25 Feb 2018 at 2:11pm
Congratulations and welcome to DS.Awesome Echo bprat22, make sure there is room to breathe and send us a pic or two. We like to admire Droolingother's systems set ups.
Big%20Smile
  Quote andr.del Quote  Post ReplyReply bullet Posted: 25 Feb 2018 at 6:18pm
Will do mates! Thank you kindly for the responses - and I’ll heed your advice re: leaving room to breath!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 25 Feb 2018 at 9:59pm
I'm sorry fellas, I've forgotten, but someone wanna tell him how to get the "verified customer" badge?
  Quote Snaike Quote  Post ReplyReply bullet Posted: 26 Feb 2018 at 2:37am
"Verified Customer" is simply ensuring that your order email address and forum email address are "EXACTLY" the same (case sensitive).
Welcome to DS and Congrats on the Bolt!
Edited by Snaike - 26 Feb 2018 at 2:37am
kriswithak View Drop Down
  Quote kriswithak Quote  Post ReplyReply bullet Posted: 09 Mar 2018 at 1:18pm
Bolt-x here, anyone know if I will be able to lay it on its side with a full custom loop? (GPU+CPU)
BOLT-X
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Mar 2018 at 1:26pm
The custom loop, the Swiftech h220 or so, has a pump pickup port that needs to stay immersed in the fluid in the reservoir.   If the reservoir stays mostly filled, then no problem.    If the fluid level lowers like it can do, you might have an issue, depending on which side.
If you do lay it on the side, use feet at 4 corners to allow airflow.
