Leak Test Question
Post Date: 2010-06-13
SWhip View Drop Down
  Quote SWhip Quote  Post ReplyReply bullet Topic: Leak Test Question
    Posted: 13 Jun 2010 at 2:55pm
Hello!
I'm making some liquid cooling modifications to my computer. I'm going to be performing two leak tests (one outside the computer first and then one inside). For the outside one i'm mainly checking to make sure that my new rad and new compression fittings don't leak. Therefore my question is should i take off my CPU waterblock (which i have already been using and has proved not to leak) and test it out in the outside leak test?
The only reason i don't want to is because I wasn't sure how much of a hasstle it is to remove and then reapply thermal paste.
Opinions?
Thankyou Big%20Smile
Intel iInfiniti @ 9.9Ghz, w/ Warp Speed on (temps never get above absolute zero)
(6) Nvd GTAwesome 999s
2 Tb of Extreme Extreme Extreme Corsair High Performance DDR25 Ram
Cooling: 1 Wind Tunnel Fan
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 13 Jun 2010 at 6:24pm
removing thermal paste is easy, if you have some remover like ArtiClean. reapplying is a bit confusing, you just gotta know the best place to reapply.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote SWhip Quote  Post ReplyReply bullet Posted: 13 Jun 2010 at 10:18pm
ah
would you recommend that i still leak test it outside the PC though? or just forget it since i've been using this waterblock
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Jun 2010 at 12:03pm
if you double check, to make sure all of the fittings are tight, and of the hoses are all the way on, and clamped, and have a ton of paper towels covering everything, I would fire it up inside.
This page was generated in 3.613281E-02 seconds.
