LED coloring to LED Thermal Mode
Post Date: 2015-12-31
Masimo View Drop Down
  Quote Masimo Quote  Post ReplyReply bullet Topic: LED coloring to LED Thermal Mode
    Posted: 31 Dec 2015 at 5:15pm
Anyone know the colors associated with the heat level in Thermal Mode?
  Quote Alex Quote  Post ReplyReply bullet Posted: 02 Jan 2016 at 10:29am
Each system will have a different thermal range, as the system is dynamic to it's own environment and user. What this thermal mode does is show you the lowest and highest temps your system has been experiencing so far. Because the unit might be orange or yellow does not mean it's bad, it's just showing you that it's never gotten that high before. This allows you to see how your overall thermals are doing while using the PC.
