LED confusion - how many fans/ Corsair H100i
Post Date: 2019-03-05
Jangotat94 View Drop Down
  Quote Jangotat94 Quote  Post ReplyReply bullet Topic: LED confusion - how many fans/ Corsair H100i
    Posted: 05 Mar 2019 at 5:19pm
Hey guys, I am totally confused by the LED options.
If I chose the Corsair LL LED fan option on the Velox series in combination with the Corsair H100i, will those be installed for my Corsair H100i as well? If not, do I only get 3 Corsair LLs in the front or also one in the back? Summing this up, will I get 3,4 or 6 Corsair LLs installed if I go with that option? Thanks for answering.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 05 Mar 2019 at 6:03pm
Welcome to the forums Jangotat94 !
On my recent Lumos rig it meant all 6 positions were matching Corsair LL fans...and the same should be true with Velox.    That said, you should confirm that with DS to be real certain.
The Corsair LL Series fans are excellent, and the RGB options are endless using the Corsair iCue software.
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 05 Mar 2019 at 6:49pm
I forgot that on Velox they have to place a fan behind the motherboard cpu...that would be 7 fans.
This page was generated in 8.691406E-02 seconds.
