LED confusion - how many fans/ Corsair H100i
Post Date: 2021-12-03
Jacksom View Drop Down
  Quote Jacksom Quote  Post ReplyReply bullet Topic: LED confusion - how many fans/ Corsair H100i
    Posted: 03 Dec 2021 at 5:49am
Hey guys, I am totally confused by the LED options.
If I chose the Corsair LL LED fan option on the Velox series in combination with the Corsair H100i, will those be installed for my Corsair H100i as well? If not, do I only get 3 Corsair LLs in the front or also one in the back? Summing this up, will I get 3,4 or 6 Corsair LLs installed if I go with that option? Thanks for answering.
fwfdfireman View Drop Down
  Quote fwfdfireman Quote  Post ReplyReply bullet Posted: 03 Dec 2021 at 9:46am
All your fans will be the LLs.
I received my Velox having ordered the Corsair LL series fans BUT left the CPU cooler as the DS AIO RAd and cooler. All fans are the LL series and two of those six are mounted to the radiator. So unless you just want to spend extra to get the Corsair CPU cooler, the DS works great. I also had them intall the Corsair Commander Pro to control all my lights. All the lights on my fans and Ram are controlled through iCue. The DS Cpu cooler lights match whatever I select for my fans.
Old Gamers Never Die!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 04 Dec 2021 at 1:57am
Are you contemplating having DS special order those parts, or having them sent to DS for your build? They are no longer options currently presented here. Please let us know if DS is accepting special orders. Thanks.
