LED Fan Light?
Post Date: 2012-01-18
bbaisw View Drop Down
  Quote bbaisw Quote  Post ReplyReply bullet Topic: LED Fan Light?
    Posted: 18 Jan 2012 at 6:31pm
I've noticed there is a fan/led light on my computer. I'm assuming it's to turn off the LED light. However, when I press the button nothing happens. Does anyone have any thoughts on this.
Also, I had the Digital Storm Logo on my desktop background and somehow it had vanished. How can I get that back.
Thanks to All!
  Quote Alex Quote  Post ReplyReply bullet Posted: 23 Jan 2012 at 10:20am
That button may be for something else. If you can send pictures, we can figure it out?
In regards to our wallpaper, here you go: http://www.digitalstormonline.com/dswallpaper.jpg
  Quote FrankW Quote  Post ReplyReply bullet Posted: 23 Jan 2012 at 1:54pm
Hi bbaisw,
If you already had the logo on as wallpaper it should still be in the computer. Do a search on dswallpaper and see if you get any results. You may have to just reselect it in your Control Panel/Display settings.
VirgilAmendola View Drop Down
  Quote VirgilAmendola Quote  Post ReplyReply bullet Posted: 16 Apr 2012 at 10:53pm
I was looking at a few boats this past weekend, and would like to know what it would take to change the main halyard, and jib halyard to accessable from the cockpit.
The halyards now exit out the fore of the mast base, can that be left alone, or do I need to change the mast base as well?
If anyone else has done this, please send me pictures so that I may see where everything is routed, and located.
chasblock View Drop Down
  Quote chasblock Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 4:41am
You have to change out the kneblin pin from the left to the right side of the lanyard attachment, once you've done that it's a simple adjustment of the leichenstein spring. Make sure you give it a liberal application of meunchen cement or it will break free and leave you out on the yardarm.
Seriously, aren't there boating/sailing boards you can ask this on? This is a computer tech forum.
And your post has nothing at all to do with the topic.
  Quote Alex Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 8:49am
Wow, great response, even on a tech forum. I believe VirgilAmendola may be a SPAM bot.... Whoa
  Quote chasblock Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 10:40am
Yes sir.... my response was appropriate. LOL
I wouldn't know a mizzenmast from a focsail! Awesome
HOLLIS1947 View Drop Down
  Quote HOLLIS1947 Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 11:00am
I have the same button on mine and I also cannot find what it dose.
  Quote Alex Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 11:04am
If you can post a picture I can help you figure out what it is?
  Quote HOLLIS1947 Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 11:26am
Will do when I get home.
Thanks
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 11:48am
Do you have HafX case? Is the front fan's red LED on?  If not, the wire to the fan might've disconnected in shipping.   If led is not lit, pull off right side cover and look for a 2 pin wire hanging there.  The wires I think are red and black.   It connects to the bottom fan's simlar connector.
The top button under sliding cover marked fan/led turns on/off the front fan red led.
Edited by bprat22 - 17 Apr 2012 at 11:50am
  Quote HOLLIS1947 Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 1:38pm
Found mine. It changes the color red, white ,blue, then off.
  Quote chasblock Quote  Post ReplyReply bullet Posted: 18 Apr 2012 at 7:18am
Mine never did anything either. I'll have to check the connections. Thanks bpratt22. But I think my light is on anyhow. Unless I'm just seeing the glow off the MoBo indicator light.
After checking, I found it does turn the front fan light on and off... no color cycle...
Edited by chasblock - 20 Apr 2012 at 7:08am
VitoAdjei View Drop Down
  Quote VitoAdjei Quote  Post ReplyReply bullet Posted: 03 Sep 2012 at 10:25pm
I did all I found was a box the lights were connected to but no switch on it but on the back I found this small red switch with on and off on it I would try it but I'm affraid of it might do something wrong
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Sep 2012 at 8:03am
I believe that small red switch on back panel is for your interior light strips.  The box might be the inverter/rectifier for the same internal CCFL light strip.
  Quote Asangard Quote  Post ReplyReply bullet Posted: 04 Sep 2012 at 8:06am
bprat22 is correct the red switch on the back is for the internal light.
