LED FansPost Date: 2014-06-09 |
Seafoam
Newbie Joined: 06 Jun 2014 Online Status: Offline Posts: 49 |
Topic: LED Fans Posted: 09 Jun 2014 at 7:29pm |
So I was configuring my ODE, once again, making sure all is good. Found a category called 'Chassis Fans', now are these the only LED fans available? Do you guys have like any other color besides red, green, and blue? Just wonderin'.
Thanks! |
PC SPECS:
- Intel Core i7 4930k 3.4Ghz - ASUS Rampage IV Black Edition - 16 GB DDR3 1866MHz Corsair Vengeance Pro - 750W Corsair - Samsung 250 GB SSD - 1TB Storage - NVIDIA GeForce GTX 780 Ti 3 GB |
ArkansasWoman777
Quote Reply Posted: 09 Jun 2014 at 7:45pm |
i think you can have ds custom order you some led fans if there is a color you want for a small fee
Seafoam
Quote Reply Posted: 09 Jun 2014 at 7:48pm |
Oooooo, that'd be awesome. I wonder if there's multiple colored led fans to change to the solid color you want. Hm, would like an Admin or Mod on here to approve of this. |
PC SPECS:
Theokritos
Senior Member Joined: 28 Feb 2014 Online Status: Offline Posts: 688 |
Quote Reply Posted: 09 Jun 2014 at 9:03pm |
I doubt very much that there is a commercial product like this, but I'd love to see components coated with a temperature sensitive liquid crystal that would change colors with the temperature of the component. Something like a Mood Ring for computer hardware.
Velox
Cool and Quiet AMD Ryzen 9 7900X 32GB DDR5 5200MHz Radeon RX 7900 XTX |
Seafoam
Quote Reply Posted: 09 Jun 2014 at 9:16pm |
We need creative geniuses like you in the world. Imagine the output of that. I'm pretty sure there are fan's that can change color accordingly to a remote control or a software of some sort. I guess i'll just pick whatever color, or just probably stick to the original fans
It's hard to choose cause i'm adding Internal Lighting onto my Level 4 ODE and it can change to any color, pattern, etc. I'm afraid that if I wanted to change the color of the internal lights but can't change the color of the fans, it'd probably look a little funky. Having purple lights internally, and green fans. Or any other color for that matter. It'd be cool to have it match, or maybe some day I might get sick of having the color green, but get stuck with it. The struggles of being OCD, about colors. ._. |
PC SPECS:
Theokritos
Quote Reply Posted: 09 Jun 2014 at 9:42pm |
What is the color scheme of your motherboard? Rather than LED lighted fans, consider unlighted fans that go with your motherboard's color scheme. Your fans match your interior and you can play with the lights to your heart's content.
Velox
Seafoam
Quote Reply Posted: 09 Jun 2014 at 10:01pm |
I'm not sure of the color scheme, haven't ordered my ODE yet. I think i'll just go with unlighted LED fans and play with just the internal lights. If I ever feel comfortable with one light, i'll always upgrade.
Edited by Seafoam - 09 Jun 2014 at 10:02pm |
PC SPECS:
Ragevirusqq
Newbie Joined: 18 Feb 2014 Online Status: Offline Posts: 95 |
Quote Reply Posted: 12 Jun 2014 at 2:08pm |
do the upgrade to sp/af 120's they have inter changeable colored plastic rings. Besides being totally awesome fans! with a RGB kit i have found that particularly the blue and white rings adapt well to many colors of internal lighting. some phases even make the blue and white glow.
Seafoam
Quote Reply Posted: 12 Jun 2014 at 3:08pm |
Is it in the Digital Storm configuration? I'm not sure how to install fans, i'm not good with hardware and stuff. I just know about it. Thanks for the suggestion though, i'll look into it. I hope Digital Storm can order certain parts. That'd be cool.
PC SPECS:
ArkansasWoman777
Quote Reply Posted: 12 Jun 2014 at 6:59pm |
Yea its under CHASSIS FANS |
