LED in the Vanquish 4
Post Date: 2015-10-15
mastershots123 View Drop Down
  Quote mastershots123 Quote  Post ReplyReply bullet Topic: LED in the Vanquish 4
    Posted: 15 Oct 2015 at 11:55am
Hi guys! I just received my new vanquish 4 yesterday and i turned it on and everything and works great. The only issue I had was that there was LED lighting strip inside for cool looks and i had it  working for like 5 min and turned off and now I cant get it on again with the remote. I really don't want to send my computer in for something so little. I was wondering what is the brand for that LED strip inside so i can replace my self or does anyone have any solutions to this. Thanks.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Oct 2015 at 12:32pm
Hi mastershots123.... It might not be the led strip. Unless you can check the voltage or lack of to it then it could be the remote, inverter etc.
I'd give DS a call or email to see how they want to handle it. You're under warranty so DS will take care of it for free.
Good luck and hope this helps.
